Old October 10, 2009, 08:33 PM
Very nice. The finish looks good .
Old October 10, 2009, 08:59 PM
Yeah Nice stuff.. Green and Black go very well.. :)
Old October 11, 2009, 07:26 AM
Well, I had a hard time sleeping last night so I decided to do some sleeving. I first had to rewire my green led Thermaltakes from 4 pin molex to 3 pin so I can connect them to my fan controller. I then sleeved them with some cheap sleeving I had laying around. This sleeving won't be visible as these fans are my top exhausts.
Next, I sleeved 4 sata cables and had just enough left over to do my case switch wiring. This was done with some better stuff I ordered from Performance-PCs. The Freezone Elite you see pictured came pre-sleeved with techflex which I purchased recently. This should help somewhat with my cable management.
Size:  133.0 KBName:  DSCF0356 [].JPG
I'll be doing assembly today so I should have more pics up tonight sometime. Cheers!
Old October 11, 2009, 11:40 AM
Polygon's Avatar
wow looks sick, keep those updates coming.
'Do not wish for easier lives, wish to be stronger men'
DreamRealeSports.com
Old October 11, 2009, 03:33 PM
Wow nice sleeving, thought you'd want same color sleeving on everything.. Nice work.. :)
Old October 12, 2009, 04:36 PM
The paint is now dry and here are a few pics of the assenbled case. No components are installed yet except for the fans. Some of which will be connected to a Zalman ZM-MFC1 fan and light controller. A single green cold cathode will also be part of the build. The fans include;
2X120mm green led Thermaltake Thunderblades (top exhaust to fan controller)
1X120mm green led Coolermaster (front intake to fan controller)
1X120mm Coolermaster (left side intake to fan controller)
1X120mm Coolermaster (bottom intake to mb)
1X80X80X15mm green led Hiper (right side intake to mb)
1X green cold cathode (to fan controller)
1X120mm rear exhaust from Freezone elite.
The exhaust fans will be run at medium speed to reduce noise and maintain a positive pressure inside the case to reduce dust. The 80X80X15mm is mounted behind the right side panel behind the cpu. I hope it doesn't interfere too much with my cable management.
Name:  DSCF0367 [800x600].jpg
Size:  82.5 KBName:  DSCF0368 [800x600].jpg
Name:  DSCF0369 [800x600].jpg
Size:  109.8 KBName:  DSCF0372 [800x600].jpg
Name:  DSCF0374 [800x600].jpg
Size:  182.3 KBName:  DSCF0375 [800x600].jpg
Name:  DSCF0379 [800x600].jpg
Size:  106.9 KBName:  DSCF0380 [800x600].jpg
Name:  DSCF0398 [800x600].jpg
more to come...
Old October 23, 2009, 02:10 AM
Default Green Machine completed!
The build is complete. It took some doing, but I finally got it finished. Final pics and thoughts will be posted later this evening.
Old October 25, 2009, 09:46 PM
The Green Machine is complete except for a few tweaks. Please keep in mind that this is my first attempt at sleeving and cable management. All in all, I think the rebuild went fine. I found that the CM690 is a great case, but it is a tad small for my taste. I had to do some minor cutting to accomodate the 24pin and 2X6pin behind the motherboard. Also, an 8pin eps extension would have come in handy as well. I will definitely be upgrading to a larger case in the near future. Here are the last of the pics. Any comments positive or negative would be appreciated as I view negative comments as constructive criticism. This way I can learn a bit more for my next build.
Size:  364.7 KBName:  DSCF0411 [].jpg
Size:  322.4 KBName:  DSCF0415 [].jpg
Size:  381.7 KBName:  DSCF0424 [].jpg
Size:  381.6 KBName:  DSCF0429 [].jpg
Size:  329.8 KBName:  DSCF0433 [].jpg
Size:  325.1 KBName:  DSCF0441 [].jpg
Size:  281.2 KBName:  DSCF0449 [].jpg
Size:  271.9 KBName:  DSCF0452 [].jpg
Size:  221.5 KBName:  DSCF0478 [].jpg
Thanks for looking!
  #19 (permalink)
Old October 25, 2009, 10:46 PM
Polygon's Avatar
Really nice work mo power! I love green LED's, planning on using a green/black theme on my case too!
P.S. your 666th post. WIIIIITCH lol.
Machine burnt out. New machine needed Neutronium New Builds 15 March 18, 2009 12:23 AM
P5Q Deluxe ....Green? Brian CPU's and Motherboards 1 January 23, 2009 12:21 AM
More Green Machine "rumours".. rjbarker Rumor Mill 0 October 12, 2008 06:58 PM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 12:08 AM
Green Border/Color Changes Drader Video Cards 0 October 1, 2007 08:43 PM
