  #21 (permalink)
Old October 2, 2009, 10:28 PM
Very nice combo..
  #22 (permalink)
Old October 4, 2009, 12:14 PM
Lpfan4ever's Avatar
Test setup before I threw it into the case. Hearing the POST beep and seeing the BIOS makes me happy
Tower of sleeved fans. Sexy.
Here starts the assembly. Not much in terms of explanation here, but most of it is self explanatory.
Originally Posted by encorp
Code:
<firebane> slightly used
  #23 (permalink)
Lpfan4ever's Avatar
I've got a ton more of pictures but they're not uploaded and I have to go to work. Update later tonight after I ensure leak testing went well.
Code:
  #24 (permalink)
Old October 5, 2009, 07:30 AM
Good choice on the trident, its basically the best ddr3 on the market but no one has discovered that yet. All the sack over head yuppies who can't sleep without there corsair or crucial fancy over priced ram.. lol
  #25 (permalink)
Old October 5, 2009, 04:55 PM
Lpfan4ever's Avatar
Basically done, waiting on a shipment of fan screws from Jay51 to get here to completely finish it (Thanks!)
Here's the pile of stuff that got accumulated over the build. By the end I could barely do anything because the table was covered.
Watercooling pre-fill pictures:
Leak testing. Always the most exciting/annoying part. I had a very minor leak due to a worm clamp not being screwed down all the way. Other than that, all is good.
And the semi glamour shots. As you can see that grill is completely out of place, I am in need of those screws before I can put the other one on to match the rest.
Code:
  #26 (permalink)
Old October 5, 2009, 05:07 PM
Nice build.. Is that me or is it really some electric tape on that tube (black color).. Nice UV effect there.. :)
  #27 (permalink)
Old October 5, 2009, 05:24 PM
Lpfan4ever's Avatar
That tube is just a black primochill tube I had lying around, the clear stuff was too stiff to get in there. It looks like tape because there was a anti-kink coil on it before, left some indents.
Code:
  #28 (permalink)
Old October 5, 2009, 05:39 PM
I can't believe i never seen this worklog before now ..i did not send anywhere near enough for your intire case.
25 only,but a good start for sure
Great job
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
  #29 (permalink)
Old October 5, 2009, 05:45 PM
Lpfan4ever's Avatar
Great job
Heh. Only about 5 of them are mounted to the case, most are directly mounted onto the radiator. With that said, I only had 7 or so of the self tapping screws, so most fans like that only have 2 screws holding them in.
Code:
  #30 (permalink)
Old October 5, 2009, 10:13 PM
2 screw.. ooh risky..
I see, that tube really looked like it had electric tape, the tube coils seemed to sit tight on tubing, the effect makes it look nice though..
Been a while since I saw a worklog in one of those cube cases, and also I was wondering you're the guy with the custom white painted swiftech radiator, I was right.. it's there :p
first WC project Shadowmeph Case Mods, Worklog & Gallery 4 July 6, 2009 11:12 AM
New Build - Project 7 Sagex0 Case Mods, Worklog & Gallery 11 April 15, 2009 02:11 PM
Project: All Right S_G Case Mods, Worklog & Gallery 37 February 18, 2009 06:53 PM
Project: A+ Cardboard box with DSL Case Mods, Worklog & Gallery 33 April 14, 2008 08:40 PM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 12:08 AM
