Originally Posted by MarkOne Ah I see if it looks good it should work good too..... Why are you surprise to have no leak? Are you not confident in your work? |
I dunno, this was my first time doing any sort of significant aftermarket cooling upgrade, and like many beginners, I expected that I would make mistakes. I guess I was careful enough in the installation phase that I managed to avoid any serious issues. Let's just say, this watercooling upgrade has definitely boosted my confidence in my work
Originally Posted by ImmaPC First time posting in this thread but I've been following it from the start. Honestly. I have to say that thing looks so sexy, and I can't wait to see how it performs with those huge fans! Just where do you get the cash for all this?!?
And that 800D is just sexy. And it's extra suited for watercooling it seems, perhaps not so much for standard air cooling though. If I ever get my act together and get a WC setup, this is going to be the case for it. |
Between the RESP my parents saved for me and my full-time co-op job(s), somehow I manage to find enough cash after tuition and rent to afford crap like this. Of course, the money left over, after satisfying my tech cravings, for things like food is meager at best
We all have our priorities.
Originally Posted by miggs78 Very nice.. Proper job done mate, that looks beautiful.. You're doing the case a little in-justice not sleeving those darn cables.. C'mon :p.. |
That's next on the list miggs, just you wait
Anyway, Chronos is up and running beautifully once more. Once Windows booted up and Everest launched, I was shocked to see the extreme difference in the idle core temperatures between the stock air cooler(s) and the water cooling setup. Given a couple hours to stabilize, Everest tells me that the GPU is idling at 34ºC (previously 49ºC on air), and the idle temps on the CPU cores range from about 32ºC to 35ºC (previously between 46ºC and 49ºC with the Intel stock cooler), with my thermostat telling me it's 70ºF in here (~21ºC). When idling, no temp on the Everest sensor page reads above 36º, which seems absolutely incredible to me. This is the point where I did a little dance and relished the sweet taste of victory.
I snapped a couple of pics with everything set up once again. Here's a shot of the computer back at the desk, using the flash (god, it makes everything look so dusty
Without the flash however, you get to see the glow from the white LED stick I attached to the side of the radiator (facing downwards). It does a pretty decent job of illuminating everything, although it does miss the components right under the rad (obviously). Please excuse my awful photo equipment/skills:
Tomorrow, I'll be cranking up (and back!) the clocks, and I'll report back in once I get something I'm happy with (along with a full set of load temps, naturally
It's been a wild ride, everyone. Thanks for all your support.
