-   Case Mods, Worklog & Gallery (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/)
-   -   Starting Έρεβος (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/22158-starting.html)
Safearus August 21, 2009 07:55 PM
Starting Έρεβος
Well as I had said, I'm making a worklog for my new rig that I'm building and starting without all the parts because I have the ones that I'll be slapping in the case before anything else.
All pictures are clickable to see in full size! :punk:
Current components:
Thermaltake Armor VA8000BWS
Coolermaster Hyper 212+ HSF
Mushkin HP3 DDR3 1600 Mhz 4GB Dual Channel kit
ASUS R.O.G. Crosshair III 790FX
Corsair TX850W
AMD Phenom II X4 955
No pictures as of JUST yet but so far I've already opened everything (I'm impatient...)
My case had been sitting around for a few years in an old shed so she had some rust on 'er. Broke out the dremel and cleaned that up than sprayed her out with aerosol carbon dioxide.
Removed the stock backplate and heatsink brace from the motherboard. Removed most of the parts from my case (Hard drive racks, fans in annoying places to get stuff around, etc.
Realized that my Corsair TX850W is going to be a pain to fit in this case... will update as soon as I get the camera fully charged up and ready to go.
EDIT: Here come some pictures!
Before readying everything up
http://img.photobucket.com/albums/v6...h_DSC00407.jpg
Yes, I know the RAM isn't there, I forgot it in the other room...
All sprawled out on the dining table
http://img.photobucket.com/albums/v6...h_DSC00387.jpg
Just some randoms of the stuff...
http://img.photobucket.com/albums/v6...h_DSC00388.jpg
http://img.photobucket.com/albums/v6...h_DSC00389.jpg
http://img.photobucket.com/albums/v6...h_DSC00390.jpg
http://img.photobucket.com/albums/v6...h_DSC00391.jpg
Hmm... energy drinks ftw!
http://img.photobucket.com/albums/v6...h_DSC00394.jpg
Now, I had to remove ALL the case fans from my case for this PSU to fit in... I think I would have to for any PSU though...
http://img.photobucket.com/albums/v6...h_DSC00392.jpg
Next, yes an odd order of things... Place the RAM into the motherboard prior to putting the motherboard in my case.
http://img.photobucket.com/albums/v6...h_DSC00393.jpg
Slapped the motherboard in, screwed it in diagnally from corners to begin, than moved clockwise around.
http://img.photobucket.com/albums/v6...h_DSC00395.jpg
Power cord is nice n tight!
http://img.photobucket.com/albums/v6...h_DSC00396.jpg
PCIe1 Sound Card is in!
http://img.photobucket.com/albums/v6...h_DSC00397.jpg
Back of the case now:
http://img.photobucket.com/albums/v6...h_DSC00398.jpg
And I kinda won't need this PCI slot, so I'll throw on the extra USB ports and firewire!
http://img.photobucket.com/albums/v6...h_DSC00399.jpg
Nice start n stop buttons on the board, lotsa cable management to ensue afterwards.
http://img.photobucket.com/albums/v6...h_DSC00400.jpg
Back view again:
http://img.photobucket.com/albums/v6...h_DSC00402.jpg
Side view, shows why I need cable management.
http://img.photobucket.com/albums/v6...h_DSC00403.jpg
Can't wait to put a CPU here... just waiting on payday!
http://img.photobucket.com/albums/v6...h_DSC00404.jpg
Front of the case... I needa take my DVD-RW outta my other PC... lol
http://img.photobucket.com/albums/v6...h_DSC00405.jpg
Won't run outta mounting hardware methinks:
http://img.photobucket.com/albums/v6...h_DSC00406.jpg
Will add more ata later point!
Safearus August 21, 2009 08:00 PM
http://img.photobucket.com/albums/v6...h_DSC00419.jpg
The case in running operation!!!!
http://img.photobucket.com/albums/v6...h_DSC00421.jpg
Push config on the CM Hyper 212+ directly towards my case exhaust fan :biggrin:
http://img.photobucket.com/albums/v6...h_DSC00424.jpg
Ahh my GPU's box....
http://img.photobucket.com/albums/v6...h_DSC00422.jpg
Still have cable management to take care of.... at least I found the camera!!
ToXic August 21, 2009 11:37 PM
nice case there, i had the LCS version... it was a bitch to set up hah... good luck with the work!
jay51 August 21, 2009 11:43 PM
nice choice of HW,looking forward to your build.
subscribed :thumb:
Safearus August 22, 2009 12:19 AM
It's definately not the easiest. Removing all the case fans just to get the PSU past the supporting bracket was enough of an issue let alone removing the stupid PCI-retention bracket.
EDIT: Might be using an nVidia 7300GS 512MB as a temp card just to get this rig running. That way I can buy the CPU and I need a new optical drive cause my SATA DVD-RW died on me... stupid used parts :censored:
Safearus August 28, 2009 04:32 AM
Update; Just ordered:
  • Phenom II X4 955 (3.2Ghz Stock)
  • Samsung SH-S223B/BEBE 22X DVD+-RW SATA DVD
Will update with more pics once I put them in, also using an nVidia 7300 GS 512MB just to get this rig running...
DunF88 August 28, 2009 05:09 AM
! thats cool, loll all sprawled out on the table..dontcha just love seeing all ur fresh parts just waiting to be built
Safearus August 28, 2009 08:06 AM
That I do, however I've been waiting 2 years to use that damned case... :shok:
I still need to finish removing the rust from the HDD rack that mounts in the 5.25" ports. I'm missing a 120mm fan right now because of that issue! :angry2:
Not to mention that I feel kinda pathetic using a GeForce 7300 GS 512MB card with the rest of these components for the time being... *le sigh*
DunF88 August 28, 2009 09:48 AM
hah that sucks ! im sittin here waiting for ups to deliver the case for my build, so i know how u feel on having one thing missing from the overall final build lol it sucks !!!!!
