-   Case Mods, Worklog & Gallery (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/)
-   -   Sappire 4870X2 Baking Process (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/21130-sappire-4870x2-baking-process.html)
AmuseMe July 24, 2009 10:00 AM
If anyone would like to know how I got to this point, please refer to http://www.hardwarecanucks.com/forum...ew-4870x2.html
About two weeks, maybe three weeks ago, my 4870X2 started crashing my computer. After one 'major' crash, the computer just simply wouldnt boot. UHOH! I thought maybe I fried something, maybe the card broke the PCIE slot, or maybe my old cheap BioStar motherboard gave up. I tried the card on three different rigs, and still nothing.
I than took the card to some proffessionals, who almost charged be $50 for a system diagnostic. They told me, "We have reaon to believe it is your videocard. We stripped the whole thing down, tried each and every single part individually, and only the video card had error".
Anyways, I replied with "Your telling me, I need to pay you $50, just to have you tell me that my $xxx [included their shop price] video card is toast? I know you put in over 40+ hours, but damn..." They felt bad, and since I do business with them a little more than average, they gave me deal.
As of right now, my computer is still in their shop, but I took the video card. They told me "You do anything and everything you can to get this working, eh champ" [<-- over exagerated sentance]
I than went home, and was thinking, do I sell it? Put the stock cooler on and attempt an RMA? Or what? I than saw Braineaters "die 680i die" thread and in clicked! Mr. 4870X2, meet Louisville Slugger. Before I made sycg a crazy dicission I posted a thread here on HWC seeking out some final opinions etc. I got a reply about the "Baking method". I have read this before, but totally forgot. Well, this card is garbage right now, what harm does sticking it in the oven do?
(For those who have not heard of the baking method. Its where you strip the video card 'naked' and place it in an oven at the correct heat. What this does is re-melt the solder, which flows into any little cracks or fissure - I think :thumb:)
Picture1: Pre-baking.
http://img339.imageshack.us/img339/6000/image1t.jpg
Picture 2: Different Angle
http://img269.imageshack.us/img269/3320/image2nht.jpg
Picture 3: Another Angle
http://img10.imageshack.us/img10/9873/image3xdg.jpg
Picture 4: Angle Shot
http://img193.imageshack.us/img193/387/image4tdu.jpg
Picture 5: Bottom View w/ Backplate (No retention brackets)
http://img505.imageshack.us/img505/5672/image5yjv.jpg
Picture 6: Complete Shot of both units - naked and dirty... with gunk
http://img10.imageshack.us/img10/6537/image6vow.jpg
Picture 7: Blury Shot of the Naked Video Card
http://img258.imageshack.us/img258/8113/image7m.jpg
Picture 8: Zoom in on GPUs
http://img110.imageshack.us/img110/4618/image8f.jpg
Picture 9: Dirst Heat Sink
http://img269.imageshack.us/img269/926/image9xrl.jpg
Picture 10: All Cleaned and Ready to go [please note I forgot to remove some plastic parts - and yes, they went into the oven]
http://img156.imageshack.us/img156/2456/image10k.jpg
Picture 11: On tinfoil lifts, ready to go!!!
http://img505.imageshack.us/img505/4194/image11nnf.jpg
Picture 12: Look at those shiny mirror finished chips!
http://img339.imageshack.us/img339/5103/image12g.jpg
Picture 13: Oven temp
http://img156.imageshack.us/img156/4831/image13d.jpg
Picture 14: Looking through the oven door
http://img338.imageshack.us/img338/5915/image14.jpg
Picture 15: Pulled out after 7m30s at 385F
http://img156.imageshack.us/img156/5348/image15xyo.jpg
Picture 16: View of the plastic [it survived]
http://img338.imageshack.us/img338/8454/image16t.jpg
Picture 17: DVI-ports, no damage
http://img10.imageshack.us/img10/248/image17wst.jpg
Will be posting more soon
AmuseMe July 24, 2009 10:07 AM
reserved .
reserved .
punk_zappa July 24, 2009 10:12 AM
It will be such a delight.
Devious July 25, 2009 11:35 AM
Crazy, can't wait to see if it worked.
Perineum July 25, 2009 11:43 AM
It can work... I did it successfully with a keyboard PCB
DarKStar July 25, 2009 11:46 AM
LOL - next time you can add in a little shake'n'bake for flavour ;-)
I'm ANXIOUSLY waiting for your results - (might actually work too LOL!)
lowfat July 25, 2009 12:23 PM
I tried this with my HD4870. It did not work.
SKYMTL July 25, 2009 04:55 PM
Need to bake at 425 for 7 minutes for an ATI card as they use slightly different solder. It worked for one of my dead HD 4870 X2s.
Perineum July 25, 2009 05:49 PM
Yeah, I used 425 as well...
