Old June 26, 2009, 06:56 AM
Beermaster's Avatar
Default Project: Tathar
Well happy days, 99% of my parts are in and ready!
I finally got permission from the wife to build a new box, my old computer gave out on me. So i decided to spend a little more money that i would, and make a very nice attempt at a custom build, then just buy a kit and slap it together in a case with cable management.
Parts list
Motherboard - Gigabyte EP45-UD3P
CPU - Q9550
Video - GTX275 BFG
RAM - OCZ Reaper 4Gb PC-8500 x2
Data HDD -WD 1Tb WD1001FALS Caviar Black
OS Drive - OCZ Vertex 120Gb
Case - Cooler Master Cosmos S Full Tower
WaterCooling Parts List
1x EK-ANTI-CyclonEK-ANTI-Cyclon
1x TFC Xchanger - High Performance Triple Radiator 360
1x EK-D5 X-TOP - Acetal G1/4 Rev.2EK-D5 X-TOP - Acetal G1/4 Rev.2
1x Swiftech MCP 655-01 Water Pump
1x EK-Multioption RES 150EK-Multioption RES 150
3x GELID Wing 12 1500 RPM UV Blue 120MM 64.3CFM
2x K - Coolant Fill Port / Drain ValveK - Coolant Fill Port / Drain Valve
6x TFC - High Flow Fitting G1/4" - 3/8"ID - 1/2"OD 45 Rotary
4x TFC - High Flow Fitting G1/4" - 3/8"ID - 1/2"OD with O-Ring
10' Feser Tube UV Hose - 3/8" ID - 1/2" OD - UV Blue (1')
1x EK-Supreme-PlexiEK-Supreme-Plexi
1x EK Supreme Backplate CPU LGA755
Still missing the OCZ SSD but will pick that up today.
Now do i need a power supply? i currently have a HX520w will this be good enough??
Grovian - *E4300@2.2ghz*Gigabyte DS3L*G.SKILL F2-6400CL5D-2GBNQ 3x1Gb*Sapphire HD4850 1GB*Raptor 75Gb*
Buggz - *E7200@2.9ghz*Asus P5Q*Patriot PC2-6400*eVGA 8800GTS 320gb*WD 160GB CaviarSE*
Lil-Grov – Acer One*8gb SSD*WinXP pro
Tathar – WIP*Q9550*Gigabyte EP45-UD3P*OCZ Reaper PC-8500 4gbX2*OCZ Vertex 120gb*WD 1TB WD1001FALS*BFG GTX275*
Old June 26, 2009, 09:53 AM
jcmaz's Avatar
Probably not.
-Plato
Old June 26, 2009, 11:58 AM
Beermaster's Avatar
Okay, thank you
So I went to get some powder coating done on the case, I tried before to get prices, but they wanted to see it first~
So bring the case in, and the bastards quoted me $400.00 to powder coat the frame black, grrrrr. Took it to a couple different company's around here, and they where all $350-$500. man what a rip off. I talked to a buddy of mine that does custom cars and he was telling me that Edmonton is the biggest rip off for powder coating anywhere in Canada!
Well guess i gotta pick up some paint grrrrrrrrr
*posted from my Blackberry
Old June 27, 2009, 12:32 PM
dragoonxx's Avatar
powder isnt cheap to do, the cost of the ovens is mostly what you pay for, if you have a large enough oven to do it yourself, it isnt difficult, but its a matter of needing to have a large enough oven that can get to a high enough temperature (I have a friend who's a pro painter also)
Old June 27, 2009, 12:33 PM
3.0charlie's Avatar
The HX520W should have plenty of power for your rig.
Hydro-Quebec is salivating...
Old June 27, 2009, 12:43 PM
be very careful with painting the case yourself!
if you dont use the right kind of paint, and if you dont do it correctly (which takes a lot of time) the paint can, and will chip/peel off. Not only will it look ugly, but do you really want paint chips falling onto your hardware and heating up? Could cause major problems.
Honestly, if you want a black frame, go with one of these 3 cases
Antec Nine Hundred Two - Newegg.com - Antec Nine Hundred Two Black Steel ATX Mid Tower Computer Case - Computer Cases
Coolermaster Storm Scout - Newegg.com - COOLER MASTER Storm Scout SGC-2000-KKN1-GP Black Steel / Plastic ATX Mid Tower Computer Case - Computer Cases
NZXT Beta - Newegg.com - NZXT Beta Series CS-NT-BETA-B Black Steel / Plastic ATX Mid Tower Computer Case - Computer Cases
they already have an all black interior. The antec and CM both have a window to show it off. The NZXT one you would have to mod yourself. All 3 cases offer cable management holes and lots of room behind the mobo tray.
I just picked up the storm scout for myself, and i LOVE it. check out some of the video reviews on these cases.
How much did you spend on the case you picked up? If i were you, id return it and use the money on one of these. Personally I can recommend the storm scout, but if you want to save some money the Beta is only $40 right now. If you have a little more money to play with the antec is the most expensive of the 3. The Scout is prolly the best bang for your buck tho
Old June 27, 2009, 02:06 PM
Phobia's Avatar
Lots of people have painted their cases and have had no problems. Keep the case, its a nice case. If you are actually really worried about it, take it in to get powder coated.
(whitty saying to be plagiarized at a later date)
Old June 28, 2009, 11:19 AM
I've painted the cosmos S, it's EASY to paint the inside on that thing!
Old June 28, 2009, 12:33 PM
Beermaster's Avatar
Okay this WC still is stressful lol
trying to figure out how to run the lines, do the loop ect ect
I have everything test mounted and try to visulize it, but figured i would come to the experts lol
just some pics to see what i see
Old June 28, 2009, 12:52 PM
3.0charlie's Avatar
No go. Res has to be higher than pump inlet. And I would try to setup the rad with the barbs out back, closer to the CPU block. Less tubing than way.
first WC project Shadowmeph Case Mods, Worklog & Gallery 4 July 6, 2009 11:12 AM
Project: All Right S_G Case Mods, Worklog & Gallery 37 February 18, 2009 07:53 PM
Project: A+ Cardboard box with DSL Case Mods, Worklog & Gallery 33 April 14, 2008 08:40 PM
Large project James_8970 HTPC Systems & Software 6 January 9, 2008 10:44 PM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 01:08 AM
