  #71 (permalink)
Old March 19, 2009, 09:00 PM
CMetaphor's Avatar
Quadfather
Default Challenge over!
... and the winner is.... Me? lol...
Found my solution(s):
Noctua NH-U9DO or Noctua NH-U12DO - Just going to call supermicro tomorrow and see how much weight their motherboard can handle.... im not too sure about 4x 120mm Tower HSFs with 5x 120mm fans between them... Thanks for all your input so far 3.0charlie & Encorp!
  #72 (permalink)
Old March 20, 2009, 09:48 AM
CMetaphor's Avatar
Quadfather
Hmmmm, A Dilemma! The NH-U12Do (which would be my preference since it uses 120mm fans) weighs in at 580g without a fan.... x 4 = (converted) over 5 lbs!!!! Without Fans!! I have a feel this may not be safe, however, A supermicro technician said it "should be" within spec given that each cooler will have it's own backplate that is designed to hold up to 1Kg each. Thoughts anyone?
  #73 (permalink)
Old March 20, 2009, 10:01 AM
3.0charlie's Avatar
It's well distributed weight - should not be a problem, especially with a backplate.
Hydro-Quebec is salivating...
  #74 (permalink)
Old March 20, 2009, 10:17 AM
CMetaphor's Avatar
Quadfather
Excellent! Modding + 2x 230mms + Noctua NH-U12Do's are now The Plan
  #75 (permalink)
Old March 20, 2009, 10:48 AM
That is suuuuuch a hot cooler.. this is going to look SIICK!
Soo stoked! haha
p.s. does that thing come with all the fans you'll need?
  #76 (permalink)
Old March 20, 2009, 01:19 PM
CMetaphor's Avatar
Quadfather
You mean the salmon/flesh colored monstrosities? Yes... it does. No, i will probably NOT be using them.... I've always had a weak spot for CM Blue Led fans.... and this build, like all my previous builds, shall glow BLUE dangit... hehe. For case fans though, Im not sure yet, but I still love Nexus Real Silents... Classy....
  #77 (permalink)
Old March 20, 2009, 01:37 PM
I looooooove Noctua fans... but my new build is changing looks so I've ordered up 6 Nexus Black/White's... I had a bunch of noctua's here and was going to offer em up if you needed em... BAH too bad now hahaha I'll sell em! :P
  #78 (permalink)
Old March 20, 2009, 01:40 PM
CMetaphor's Avatar
Quadfather
Damn.... I'll probably have to sell mine then too.... lol.
EDIT:
PS: 4x Noctua NH-U12Do's ordered!
  #79 (permalink)
Old March 22, 2009, 08:08 AM
CMetaphor's Avatar
Quadfather
Case, Motherboard & CPU HSFs are due to arrive this week (hopefully)! Stay tuned for more pictures at the start of the BUILD!
  #80 (permalink)
Old March 22, 2009, 02:33 PM
arekieh's Avatar
Edited again, GTX295 is now confirmed thanks to Arekieh! (Thanks dude!) Now just need to sell my 4870x2 and Silverstone 1Kw PSU. Check my FS Thread peoples!
Glad my mishap turned out for the better :). Your build looks insane. good luck with it
Mobo: Asus P6T Deluxe | CPU: i7 940 | Ram: 3x2 GB | HSF: CM V8 | GPU: HD 6950 | PSU: PCP&C 750W | ]HDD: WD 500gb x3, 120GB Vertex 2 | Case: Antec 1200 | Monitor: 3x Asus VE247H | OS: Win7 Ultimate x64
My Trading Rep:
HWC
OCN
Heat
Ebay
Project: All Right S_G Case Mods, Worklog & Gallery 37 February 18, 2009 07:53 PM
Project: P190 MpG Case Mods, Worklog & Gallery 44 May 7, 2008 08:47 PM
Project: A+ Cardboard box with DSL Case Mods, Worklog & Gallery 33 April 14, 2008 08:40 PM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 01:08 AM
Project Darkside BALISTX Case Mods, Worklog & Gallery 44 October 14, 2007 06:44 PM
