  #61 (permalink)
Old March 19, 2009, 07:36 PM
CMetaphor's Avatar
Quadfather
Oh they Might fit... its another option.... Idea = Use towers in up/down configuration and then use two High CFM fans at the back to PULL the heat out (the top CPU would actually be pushing air Downwards towards the 120mms....
  #62 (permalink)
Old March 19, 2009, 07:40 PM
3.0charlie's Avatar
That would work...
Hydro-Quebec is salivating...
  #63 (permalink)
Old March 19, 2009, 07:42 PM
CMetaphor's Avatar
Quadfather
Definitely not pretty.... but what would i do about CPU1&CPU2.... two towers one on top of eachother, could do a push-thru-pull between them, but where do i push the air? To only has an 80mm.... bottom.... even less....
  #64 (permalink)
Old March 19, 2009, 07:47 PM
3.0charlie's Avatar
Yup, push-pull on the HSFs. If you create front-back airflow, the chips will be fine.
  #65 (permalink)
Old March 19, 2009, 07:49 PM
CMetaphor's Avatar
Quadfather
But i cant do push-pull from front to back on the CPU1/2 HSFs... only top/bottom... should i mod my spanking new stacker 810?....
  #66 (permalink)
Old March 19, 2009, 07:53 PM
3.0charlie's Avatar
No, that's not what I meant. Push-pull vertically on the HSFs, but your case airflow front-to-back. Or heck punch a hole through the top of the case...
  #67 (permalink)
Old March 19, 2009, 07:54 PM
CMetaphor's Avatar
Quadfather
Well... I do have a couple of spare 230mm CM fans..... Hmmmm....
  #68 (permalink)
Old March 19, 2009, 08:01 PM
Chilly's Avatar
You wouldn't have this issue if you watercooled
  #69 (permalink)
Old March 19, 2009, 08:02 PM
3.0charlie's Avatar
  #70 (permalink)
Old March 19, 2009, 08:03 PM
CMetaphor's Avatar
Quadfather
Again... watercooling = $500-600 or more... Air cooling is half that or less...
Project: All Right S_G Case Mods, Worklog & Gallery 37 February 18, 2009 07:53 PM
Project: P190 MpG Case Mods, Worklog & Gallery 44 May 7, 2008 08:47 PM
Project: A+ Cardboard box with DSL Case Mods, Worklog & Gallery 33 April 14, 2008 08:40 PM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 01:08 AM
Project Darkside BALISTX Case Mods, Worklog & Gallery 44 October 14, 2007 06:44 PM
