  #51 (permalink)
Old March 18, 2009, 07:30 PM
Chilly's Avatar
Looking good!
"Let's face it, we're not changing the world. We're building a product that helps people buy more crap - and watch porn."
Bill Watkins, CEO Seagate Technology
Dual Xeon X5650 @ 4.1GHz | EVGA Classified SR-2
2x4GB G.Skill at 1496MHz (9-9-9-24) | XFX 4890 XXX 1GB at 1000/1000MHz
Intel SSD X25-M 80GB Gen2 | Western Digital 1TB Black | SilverStone Zeus 1200W
Sound Blaster X-Fi XtremeMusic | Sony MDR-V700 | Windows Seven x64
Stuff for Sale! You must buy it, you can't look away!
  #52 (permalink)
Old March 19, 2009, 06:54 PM
CMetaphor's Avatar
Quadfather
Default Cooling Challenge!!
Alright then, loyal readers and supporters of this project, I would like to pick your collective brains. As some of you do -but more likely do not- know, a Socket F/1207 cooler can have two "mounting pitch" variations. The variations are 3.5'' and 4.1''. To be blunt, those of you that have motherboards with the 4.1'' mounting pitch... you have my condolences - you're pretty much limited to handful of awful dynatron/server-class coolers that scream at well over 40db. Thankfully, the motherboard I've chosen for this project, the Supermicro H8QM3-2, uses 3.5'' mounting pitch. Now here's something else you may or may not know - 3.5'' mount pitch is exactly the same a AMD 939 bolt-thru. I say bolt-thru because the retention clip system differ between 1207 and 939, but the whole spacing and (from what I can tell) the backplate are exactly the same. So with all of that out of the way...
Here is my challenge:
According to my guestimates of the maximum available space for the heatsinks, I can use heatsinks that have a maximum width (width as in up/down size) of 79-80mm. Yup, that small. So the challenge is, can anyone help me find a 939 Heatsink that uses a bolt-thru retention system that is no larger than 80mm wide and hopefully a tower heatsink and orients airflow towards the back of the case? It's a tall order I know, but together we can find it.
If no other options can be found with a tower-style heatsink, any other style will do. However, the 80mm width restriction still applies. "Why?" you may ask, "Why does the width matter if the heatsinks can rise over the Ram slots?" The problem is, the ram slots arent an issue at all. CPU sockets 1 & 2 are directly adject to eachother, CPU 3's socket is very, very close to the top edge of the motherboard (and therefore close to the top edge of the case) and CPU 4's socket is directly beside the PCI-express 16 slot. Tough cookies for me.
Before anyone else yells at me to use watercooling: I did some quick pricing out of a WC kit for all 4 processors that used 4x Apogee GT's, 2x MCR220-Res, 2x MCP655/355's and all the accessories and it came out to well over $600... AFTER Pricematching to other stores via NCIX. So sufficed to say, WCing is my absolute Last Resort.
So, any takers for my little challenge? I'll be sure to thank you & mention you in final build log AND I might even think up of some sort of compensation... but we'll see
Good luck...
  #53 (permalink)
Old March 19, 2009, 06:58 PM
3.0charlie's Avatar
NCIX.com - Buy Scythe Mini Ninja Heatpipe Heatsink AM2 LGA775 S478 S754 S939 80MM 2300RPM 32.2CFM 24.2DBA - SCMNJ-1000 In Canada.
edit: a tad bigger: NCIX.com - Buy Scythe Samurai Z Rev B Low Profile 2 Heatpipe CPU Heatsink LGA775 S478 AM2 S940 S939 W/ 92MM Fan - SCSMZ-1100 In Canada.
Hydro-Quebec is salivating...
  #54 (permalink)
Old March 19, 2009, 07:02 PM
CMetaphor's Avatar
Quadfather
X-nay Im afraid:
Heatsink Dimensions:
110 x 110 x 115 mm
  #55 (permalink)
Old March 19, 2009, 07:04 PM
3.0charlie's Avatar
Install the HSFs with each other's fins stacked... ;P
You need a HTPC-style HSF: Small, compact.
  #56 (permalink)
Old March 19, 2009, 07:05 PM
CMetaphor's Avatar
Quadfather
That is a possibility..... but it has to be 939 bolt thru and preferably have airflow towards the back...
  #57 (permalink)
Old March 19, 2009, 07:19 PM
CMetaphor's Avatar
Quadfather
My only option?
NCIX.com - Buy Arctic Cooling Freezer 64 LP Low Profile HTPC 3 Heatpipe Heatsink AM2 S939 3000RPM 25.4CFM - ACF64LP In Canada.
  #58 (permalink)
Old March 19, 2009, 07:23 PM
3.0charlie's Avatar
I saw it, but I don't think it can handle the heat dump of the optys.
  #59 (permalink)
Old March 19, 2009, 07:25 PM
CMetaphor's Avatar
Quadfather
Even though its loud... I could replace the fan....
Newegg.ca - Dynatron A86G 60mm 2 Ball CPU Cooler - CPU Fans & Heatsinks
  #60 (permalink)
Old March 19, 2009, 07:30 PM
3.0charlie's Avatar
Oh my. Never on one of my boards... I'd rather mod the case and fit tower HSFs instead. I've looked again at your board pic on page 4, you're sure that 4 HSFs mounted to exhaust towards the top would not fit?
Project: All Right S_G Case Mods, Worklog & Gallery 37 February 18, 2009 07:53 PM
Project: P190 MpG Case Mods, Worklog & Gallery 44 May 7, 2008 08:47 PM
Project: A+ Cardboard box with DSL Case Mods, Worklog & Gallery 33 April 14, 2008 08:40 PM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 01:08 AM
Project Darkside BALISTX Case Mods, Worklog & Gallery 44 October 14, 2007 06:44 PM
