  #31 (permalink)
Old March 17, 2009, 04:16 PM
3.0charlie's Avatar
Looking good, the dual/triple combo is plenty. Now, the only block/pump that I know of is the Swiftech model, the Apogee Drive which has 3/8" fittings. You could plumb your loop using 3/8 tubing (that's what I only use). Then your setup would work quite nicely, with quad-redundant pumps. With such a setup, you could easily cool the NB and chipset chips too.
  #32 (permalink)
Old March 17, 2009, 04:23 PM
CMetaphor's Avatar
Quadfather
The NB and chipset are very... very badly located. As in, theyre both going to be partially UNDER the GTX295... I was thinking HR-05/SLIs for those two.... And 3/8 fittings... wouldnt that offer some constriction? And does the appogee drive fit on 1207 with 3.5 mounting pitch?
  #33 (permalink)
Old March 17, 2009, 04:36 PM
CMetaphor's Avatar
Quadfather
Just checked... the only apogee drives I can find online at @ ebay for $110 USD each... It would be far cheaper to air cooling if thats the best price i can get for them...
  #34 (permalink)
Old March 17, 2009, 04:46 PM
3.0charlie's Avatar
The Apogee™ Drive is compatible with the following processors:
  • Socket 775 (Pentium® 4, Core Duo, Core 2 Duo, Extreme
  • Socket 754, 939, 940 (AMD® 64 bit processors)
  • Socket AM2 (AMD® 64 bit processors)
  • Socket F (AMD®)
You mean restriction? Definitely not with 4 pumps, and even with dual MCP-355s it would not be an issue. I will never use 1/2" tubing again: not heat dump advantage, hard to bend, and takes so much space.
Do you still have the link for your board?
  #35 (permalink)
Old March 17, 2009, 04:47 PM
CMetaphor's Avatar
Quadfather
Super Micro Computer, Inc. - Aplus Products | Motherboards | H8QM3-2
There ya go.
  #36 (permalink)
Old March 17, 2009, 04:49 PM
3.0charlie's Avatar
Air cooling will always be cheaper. But remember that for 110$, you have both the pump and block. The Apogee and MCP-355 are ~70$ each.
  #37 (permalink)
Old March 17, 2009, 04:51 PM
CMetaphor's Avatar
Quadfather
OR i could get 4x smallish tower coolers for $40 each, lol....
  #38 (permalink)
Old March 17, 2009, 04:54 PM
3.0charlie's Avatar
Most definitely! Slap some Vendetta 2s on those chips, and case closed! But wc'ing is so great...
  #39 (permalink)
Old March 17, 2009, 05:07 PM
CMetaphor's Avatar
Quadfather
LOL @ my attempt at a watercooling setup.
The problem with Aircooling though is the spacing... look how close the CPU3 is the PCI-e16 slot, or how close CPU1 + CPU2 are to eachother.... Or even how close CPU4 would be to the top of the case... very very little room there...
  #40 (permalink)
Old March 17, 2009, 05:13 PM
3.0charlie's Avatar
You got the drift very rapidly to setup a loop. That would work. Even dual duals would be fine, and cheaper.
Now, for the Air cooling, fitting tower HSFs will be tricky. All 4 would have to be installed vertically.
Project: All Right S_G Case Mods, Worklog & Gallery 37 February 18, 2009 06:53 PM
Project: P190 MpG Case Mods, Worklog & Gallery 44 May 7, 2008 08:47 PM
Project: A+ Cardboard box with DSL Case Mods, Worklog & Gallery 33 April 14, 2008 08:40 PM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 12:08 AM
Project Darkside BALISTX Case Mods, Worklog & Gallery 44 October 14, 2007 06:44 PM
