Old January 26, 2009, 12:07 PM
Brian's Avatar
Originally Posted by The MAX View Post
Thanks guys.
The Radioactive symbol is just a white peel on decal from an auto store!
no uv or nothing. Just white.
Looks cool though eh?
Also.
This is the controler
NCIX.com - Buy Sunbeam 4 Port Rheobus Fan Controller Kit Black - RHK-BA In Canada.
But the LED's are normally SUPER bright. Not good if its sitting on your desk.
But I Opened the plastic clips and pushed the led's backinto the casing of the controller so they only look bright if you're looking straight into them, but not so bright at any angle past 10degrees or so. Worked pretty well. Easy mod!
Ahh very cool! Guess I should have got the 4 port since it looks that much better! Got the 6 right now and only using 2...
The decal looks good, especially under the light.
Old January 26, 2009, 02:05 PM
The MAX's Avatar
Originally Posted by element291 View Post
Looks pretty cool! The only think I can say is HOLY electrical tape on the back ;) Talk about cable management. hehehe
Haha yeah
That's not half as bad as it was though. I striped all the tape off the otherday and was able to replace most of it with those few blue zipties. But still taped some stuff down so I wouldn't need an extra arm to get my side panel on. lol.
Yeah I mean I could use a 6 if I put a side fan on and my ram fan and wanted to control the CCFL's with the controler, but 4 was enough for me to control my 4 fans. If I get any more (side and ram) I'll just connect them straight to the mobo, but I have no need for them right now.
I also like the radioactive symbol. You can get them pretty much anywhere that sells auto parts, like canadian tire or Princess auto. They just peel on and off, no goop!
- Antec 900 (modded) - Asus P5Q-Pro - 4GB Corsair Dominator DDR2-1066 -
- Palit GTX 260 SONIC 216SP - Core 2 Duo E8400 with Xigmatek HDT-S1283 cooler - 850watt Antec True Power Quattro -
Old January 26, 2009, 03:03 PM
Eagle Eye's Avatar
Looks great MAX, all thats needed is a quick shot of black paint to that PSU and it would be complete.
Old January 26, 2009, 03:27 PM
The MAX's Avatar
I was thinking about it but I'm hesitant to void PSU warranty, as Antec has a pretty decent warranty for those things.
I may just get a piece of thin 90* aluminum to cover the side and top of the psu and paint it black. that way I get the looks but still have my butt covered if the thing breaks on me.
Old January 26, 2009, 05:48 PM
Eagle Eye's Avatar
That sounds perfect and would do the trick.
Old January 26, 2009, 05:56 PM
Nodscene's Avatar
Just a comment about the sata cables at monoprice. They are of excellent quality and well worth purchasing. I bought about 15 in total, both the straight and 90 degree ones and couldn't be happier.
Create something idiot proof and they will make a better idiot.
_____________________________________
Intel Q6600 - Gigabyte EP35-DS4 - OCZ Reaper 4gig PC2-6400 - XFX 8800GT 512Mb Alpha Dog - AuzenTech X-Fi Prelude - Alesis M1Active MK2 - Corsair HX-620 - Silverstone Temjin TJ05B-X - Scythe Katana 2 - WD Raptor 150Gb - Seagate 7200.11 750Gb x2 - Samsung SH-S203N
Old January 31, 2009, 01:31 PM
norfolk's Avatar
This is my Mess.I know I gotta clean it up!Will be tackling this job on the Family Day long Weekend.
Old January 31, 2009, 06:17 PM
Eagle Eye's Avatar
Holy wires batman!!
  #19 (permalink)
Old May 31, 2009, 11:22 AM
Arinoth's Avatar
Lol its better then nothing, which is my current rig set up, but i will finally do cable management myself in my new rig, i swear i will
  #20 (permalink)
Old June 17, 2009, 01:20 PM
Poison Ivy's Avatar
Good job, looks clean and nice, like the red.
Cable Management help EaGle1337 Troubleshooting 9 January 7, 2009 06:07 AM
Cable Management :D Inik Cases 6 March 17, 2008 06:21 PM
Just another Cable Management Thread low351 Cases 2 March 17, 2008 04:48 AM
Cable management project low351 Cases 30 March 3, 2008 08:50 AM
Cable Management Challenged [droc] Case Mods, Worklog & Gallery 7 February 10, 2008 06:59 PM
