Old January 25, 2009, 11:55 AM
S_G's Avatar
S_G S_G is offline
Default Project: All Right
Lucille: How's my son?
Doctor: He's going to be all right.
Lindsay Funke: Finally some good news from this guy.
George Michael Bluth: There's no other way to take that.
Doctor: That's a great attitude. I got to tell you, if I was getting this news, I don't know that I'd take it this well.
Lucille: But you said he was alright.
Doctor: Yes, he's lost his left hand. So he's going to be "all right."
Lucille: You son of a bitch. I hate this doctor.
Lindsay Funke: How do we keep getting this guy?
Michael: Mom, he's a very literal man.
Doctor: Yes, that's more the way I would take the news.
Well then, now that you know where I got the project name from, let's move on. (If you didn't get it, it's in reference to the flipped orientation of the case.) The parts...
The system:
Intel D5400XS "Skulltrail" motherboard
16GB (4x4GB) FB-DIMM DDR2-800 (I wanted 32GB, but I couldn't afford the $2500 price tag, and I don't know if ST even supports beyond 16GB)
2x Intel E5330 Clovertown quad-core CPUs
OCZ EliteXStream 1000
That's right, fellas. Dumping the i7 system and going back to Skulltrail.
The rest:
Feser Tube 3/8" ID, 1/2" OD (Silver)
Bitspower "Black Sparkle" 90 degree 1/2" barbs (on rad) x2
Bitspower "Dark Nickel-plated" 1/2" barbs (on blocks/pump) x6
Feser One X-360 Triple Xchanger rad
XSPC X2O 400 res with submerged pump
D-Tek FuZion CPU blocks (v1) x2
and the pièce de résistance, the Tagan Black Pearl.
It'll be going in for powder coating. Haven't decided whether I will do a black or dark metallic red yet. Here's a quick mock-up I threw together in Photoshop. It won't look like this, really. I stole this pic from lowfat's Black Pearl worklog and colored it. Mine will still have the hard drive bays and won't have a triple rad in the middle, it'll be at the top or rear. And the colors are not precise, it'll most likely be a different shade of one of these:
HTPC: MSI Z77A-G43 + i5-3570k@4.6 + 16GB DDR3-1600 + GTX 580 + X-Fi Platinum on water
Work: 13" MacBook Pro Retina 512GB
Old Workstation: X7DWA-N : 2x Xeon E5330 Quads @ 3GHz + 24GB FB-DIMM DDR2-800 on water
1x 8800 Ultra --> Sony GDM-FW900 + LVM-37w3se // HT Omega Striker ~ (optical) Pioneer SE-DIR800C ~+ SE-DHP800 / HD 280 Pro
Old January 25, 2009, 01:44 PM
I didn't want to say the line "S_g you SOB" :P
Looks great, sub'ed to it. Good Luck
Old January 25, 2009, 01:55 PM
arekieh's Avatar
looks sweet
i liked the red
Mobo: Asus P6T Deluxe | CPU: i7 940 | Ram: 3x2 GB | HSF: CM V8 | GPU: HD 6950 | PSU: PCP&C 750W | ]HDD: WD 500gb x3, 120GB Vertex 2 | Case: Antec 1200 | Monitor: 3x Asus VE247H | OS: Win7 Ultimate x64
My Trading Rep:
HWC
OCN
Heat
Ebay
Old January 25, 2009, 02:59 PM
Caznoob's Avatar
I too would go for the red.
Old January 25, 2009, 06:32 PM
+1 for the red
Back up - Ebay (Inik1) or Heatware
Old January 25, 2009, 06:38 PM
Chilly's Avatar
Go for the red!
S_G's Avatar
S_G S_G is offline
Doing some more mocking up, getting a feel for what to powder coat. Here's a couple of ideas I had if I go with red on the inside:
Not sure if I like the red drive bay covers. I will probably just avoid touching the exterior colors, they look great as-is.
That's probably it for now. More when the parts start arriving. Thinking about integrating a sort of "waterfall" into the window. All I'd need is another thin sheet of clear plastic, cut to the window size with threaded holes for barbs, then held together ~5mm apart with silicone or something. Would probably hinder cooling, but it'd look badass. Quick mock-up of that idea:
Old January 25, 2009, 10:36 PM
Phobia's Avatar
i like the red on the inside, and leaving the drive covers black. The waterfall would be cool. What about putting it on its own "loop"? Just get a cheap pump, and use that, you wouldn't need a rad or anything. If you didn't, i could see the waterfall as being a huge flow killer.
(whitty saying to be plagiarized at a later date)
Old January 26, 2009, 08:37 AM
Well S_G, Red's my fav color. So the drive bays only colored in Red I think does stand out, espcially kind of metallic color.
Oh and like did you copy lowfat's design lol!!.. I just gave you the link for reference, now he's gonna come after me :D
Gr8 work though.. Can't wait to see your temps with that Feser rad, it's supposed to be pretty good.
Old January 26, 2009, 09:17 AM
S_G's Avatar
S_G S_G is offline
Yeah, I'm kind of split myself. I like the red because it makes the case stand out immediately, just by glancing at it. On the other hand, it kind of feels out of place, which is why I like the standard black. Alternatively, I could line the backs of the drive covers with red LEDs, which would emit a "glowing" effect through the cracks of the drive bays.
Probably a little too difficult to accomplish, as I'd need to find the right color, and there's no real guarantee that it would glow evenly around the edges, so I will stick to either red or black.
And no, haha, I didn't copy lowfat's design. I just needed a picture of the frame that I could color, so I used lowfat's, because it was the easiest one to use. As I explained in my first post, mine won't actually look as pictured. I won't be adding a rad in the middle, and I won't be removing the 3.5" drive trays.
What if I had the fittings angled upwards/downwards respectively, and increased the spacing of the acrylic window to 1cm? That should alleviate most of the flow interference.
Also, after thinking about it, it won't be a waterfall. Because the radiator will be at the top of my system, it is likely that the entire window will covered by water. For there to be any air in the window, the window would have to be the highest part of my loop, and what you'd really see is the pumped water flowing through it, like in an aquarium.
Project 5749 Dashock HardwareCanucks F@H Team 14 November 29, 2008 01:52 AM
Project: P190 MpG Case Mods, Worklog & Gallery 44 May 7, 2008 08:47 PM
Project: A+ Cardboard box with DSL Case Mods, Worklog & Gallery 33 April 14, 2008 08:40 PM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 01:08 AM
Project Darkside BALISTX Case Mods, Worklog & Gallery 44 October 14, 2007 06:44 PM
