Yes I did move the HDD cage back about 75mm. It can be tricky to get things all lined up you have to pretty exact with your measurements or things won't line up correctly even mine is a little off. I secured the bottom HDD cage with fanscrews, although I'd encourage you to use a small bolt or even rivet the the case again. I'll upload some more pics so you guys have a better idea of what you'll be getting yourself into, there is also the option of using a 120x120x15mm case fan which might allow you to not have to remove the HDD cage for it to fit, I acutally encourage this.
As you can see though we all wish Antec did it in the first place, while the middle fan helps clearly having a fan in the front results in much better HDD temps.
@SiD I used this program
CPUID
EE
