Originally Posted by bissa if someone has not already pointed this out, you should have the radiator fans blowing up out of the case. I noticed in the first incarnation of this that you had the fans blowing into the case and that would mean you would end up with a very high internal temperature because you would keep pumping heat into the case. otherwise, this looks like a nice build and I look forward to seeing what it ends up looking like. |
Yep good point, and I have decided to have the fans blowing up out of the case.
Not sure what kind of orientation I should have for the other fans though.... Hmmmm
