<~----> [PROJECT]: "The blank.box" - Page 2 - Hardware Canucks
Old January 1, 2009, 02:19 PM
Man some project you going there. Looks very good so far, nice work.. I like those TT 130mm fans, they look neat really..
Old January 1, 2009, 02:57 PM
LCB001's Avatar
Folding Captain
Can't wait to see where this goes, looking good...
Folding For Team 54196
Old January 2, 2009, 12:42 AM
smee's Avatar
THanks!
Update:
Hmmmm....
1-1-09
So I had an urge the other day...... to, get a second case...
The urge... to do something like this:
(picture from user "jedda" at XS)
Bolting two case's together to make one.
Doing this, will allow me to have more space, I could put the PSU behind the mobo (unseen), then add a MCR320 at the bottom of the current case (the one I have now), then add an MCR320 at the top of the other one, and more rad's... etc...
So I ordered a second case!! :D
And after 4 hours in Google Sketchup...
Here's the basic concept of what I'm thinking for the two case's together:
Then yesterday morning... I got to some more (6 hours) or sketchup:
(btw, the case sketchup is at precise measurements of the real thing. :up:)
What do you guys think about this?
Also, where should I put the pumps??? (two loops if you haven't noticed)
Suggestions please. :D
Hehe....
Old January 2, 2009, 01:02 AM
chouchou's Avatar
looks great....
im baffled
can't wait for the final!
Old January 2, 2009, 06:08 AM
Its kinda hard to say with the pics, but I think try and place the pump right beside the rad you got horizontal on both cases, the one at the bottom, seems to be some space there, enough also to allow room for the psu cables.
Old January 2, 2009, 12:29 PM
chibi_man's Avatar
Looks like a fairly well planned project. Be warned with your watercooling. All that extra items in a case will make it pretty difficult to get your cables all hooked up. Another note if I may. Your inside case temp will be higher then room temp, judging by your design all the rads will be sucking the cases heat out thru the rads. It's likely your core temps will be risen a few good degrees. I hope the processor lapping job of yours works good.
Can't wait to see it finished, shes a beauty to me.
_____________________________________
If you can't beat it... SMASH IT!!!
Old January 2, 2009, 03:50 PM
okay, maybe I'm looking at the pic wrong...but why are there two fans on the bottom of the case? does it have to do with watercooling or a special desk it's going to be on??
Current Rig:
Lightning
ASUS Striker Extreme \\ E6850 @ 3.0GHz \\ 8800GT \\ 2GB \\ WD 750GB \\ BFG 800W \\ NZXT Apollo
Soon up and running:
Thunder
ASUS Rampage II Gene \\ Intel i7 920 \\ EVGA GTX 275 \\ Corsair 6GB 1600MHz 7-7-7-20 \\ WD Caviar Black 640GB \\ Blu Ray Drive \\ Corsair HX620W \\ NZXT Rogue
Old January 2, 2009, 03:58 PM
sswilson's Avatar
If you look at the image above it you'll see he's got a rad set in there. :)
  #19 (permalink)
Old January 2, 2009, 06:33 PM
magictorch's Avatar
Very impressive! A lot of high quality fabrication work here to get a clean looking internal wc setup.
Glad you moved to a double case as it was starting to look a little tight
  #20 (permalink)
Old January 3, 2009, 01:28 AM
smee's Avatar
Originally Posted by chouchou View Post
looks great....
im baffled
Thanks!! Yea I'm looking forward to getting this build rolling! More stuff on it's way. :)
I guess I get what your saying there....
We'll see once I get the case and more rads... Thanks! :)
Yep I'm aware of major heat output, I'm thinking about flipping the rads/fans at the top to push air out... but you won't be seeing the fans through the top (if that makes sense)
There ya go.
Thanks!
second case is on it's way!
Tags
"the blank.box" , blankbox , project , worklog
Project "Gettin' out of the Ghetto" biff Case Mods, Worklog & Gallery 89 December 5, 2009 03:08 PM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 12:08 AM
Project "XETM" - Worklog Patriote Case Mods, Worklog & Gallery 59 December 15, 2007 05:18 PM
My up-coming project! It's called "XETM" Patriote Case Mods, Worklog & Gallery 23 September 25, 2007 09:50 PM
