Old December 4, 2008, 05:33 PM
I have the same case, lol!
looks like a sick build!
Current Rig:
Lightning
ASUS Striker Extreme \\ E6850 @ 3.0GHz \\ 8800GT \\ 2GB \\ WD 750GB \\ BFG 800W \\ NZXT Apollo
Soon up and running:
Thunder
ASUS Rampage II Gene \\ Intel i7 920 \\ EVGA GTX 275 \\ Corsair 6GB 1600MHz 7-7-7-20 \\ WD Caviar Black 640GB \\ Blu Ray Drive \\ Corsair HX620W \\ NZXT Rogue
Old December 4, 2008, 09:39 PM
BALISTX's Avatar
Thanks guys. Yeah it is going to be a sick build for sure. I didn't get a chance tonight to do anything else with it, but the weekend is coming so I should be able to do some more on it. I picked up a container of zip ties for the cable management, and there is a lot of space in the unused drive bays to hide the extra wires.
I look at the unsleeved wires and I want to do something about them. Unfortunately I don't have a sleeve kit, so I was wondering if using electrical tape to cover them would work?
Heatware
HWBOT
Old December 5, 2008, 07:30 AM
3.0charlie's Avatar
Electrical tape won't work. It makes the harness very stiff. Use tye-wraps every 2 inches to keep the harness at tight as possible.
Hydro-Quebec is salivating...
Old December 5, 2008, 07:42 AM
Xilikon's Avatar
Without telling how sticky it will get when you remove it in the future. Use zipties like 3.0charlie suggested.
Xilikon - Team 33
Proud to be [H]ard !
Old December 5, 2008, 08:25 AM
You know I have some good half to med roll of Vantec UV Red sleeving kit I purchased a while back but never ended up using it. I cans send it your way sir, also have some spiral wrap and wire loom (split tubing sitting), you want it. I'll send it to ya.. :)
Old December 5, 2008, 08:28 AM
Dr_BenD_over's Avatar
Fallen Folder
I've got some black sleeving I liberated from some dead PSU's (never buy Startech) and a silver sleeving kit somewhere.
All's well that's Haswell
Old December 5, 2008, 01:37 PM
WolfBane's Avatar
Looks like its gonna be a killer gaming rig:)
Old December 5, 2008, 03:42 PM
BALISTX's Avatar
Thanks guys I'll take both if you are guys are willing to send them. Just send me a PM and I'll respond back with my address.
Heatware
HWBOT
  #19 (permalink)
Old December 5, 2008, 03:54 PM
Publicly lol.. LMAO.. PM incoming :P
  #20 (permalink)
Old December 5, 2008, 04:39 PM
Fallen Folder
Still got it from before Now I just have to find the silver stuff.
