Old December 1, 2008, 07:24 PM
chouchou's Avatar
Default Rig #1! Case Mod/Paint + Build
Sup all
So after months of deciding what to buy, and hours of contemplating what to do with the case and such, I have come to a decision and I'm going to be doing a worklog on my first rig!
**A huge thanks goes out to brewer265 / RenoRacer for answering a ton of questions. Brewer also hooked up some pretty sweet things!**
I do have pictures of some parts, but others are awaiting delivery. I will be adding pics once i get things rollin!
So here goes.
The final parts:
Case : Silverstone TJ-07
CPU : Q6700
MB : eVGA 750i FTW
PSU : Corsair HX620W
RAM : 4GB Mushkin PC2-8000 Redlines
GPU : eVGA GTX 260 Core 216
HD #1 : WD Raptor 36 GB (OS)
HD #2 : WD Caviar 640 GB Black Edition (Storage)
HSF : Xigmatek HDT-S1283 w/ NF-P12
Case Fans : 3x 120mm Blue LED Yate Loons (intake) / 2x 92mm Blue LED Fans (intake) / 2x 120MM Noctoa NF-P12 (exhaust)
Here are some pictures of the parts I have. I am still awaiting on some parts to arrive: MB/GPU/HD's/Case Fans (check out my WTB -- I'm still looking for some things.)
First Job: Case Mod
First off, huge shout to brewer for hookin up an amazing case. The Silverstone TJ-07 is definitely one i never thought i could be using for my first rig, but never stop believin!
Here is a list of tasks i plan on completing before the rest of my parts arrive:
  1. Cut holes into chassis for better cable management (pictures with captions will be coming to explain each step as they are completed)
  2. Cut a 14x14 inch window on the left side panel. Gotta show the insides when i switch to H2O later on! Mount a clear acrylic window using 4010 ultra adhesive double sided 3M tape
  3. Prime the interior. 3-4 Coats of self-etching primer after a thorough clean.
  4. Paint the interior. Havn't decided on a colour yet! open to suggestions!!
Pictures will come!
Here are some original shots of the TJ-07, which I'm sure many of you are accustomed to.
Aand... after disassembly:
Update December 10/08 (HAPPY BDAY MOM!)
Ay.. sorry for the long time. Been prepping a LOT double - triple thinking everything over. Here are some pics of some holes drilled for cable management, taped up side panel etc...
awaited picssss
..and some new gear that i got - workbench is full!
Update December 12/08
sweet sweet, picked up some stuff from NCIX today! (including my MB/GPU) aaaaaaand i cut my window. tell me what you guys think!
** my..corners are hard to cut. i had an incredibly tough time cutting the edges. any tips for next time?
im still wondering on a interior colour. give me a shout if you have any ideas!
First up: Case pics (side panel cut window!)
Trusty jig saw :)
(corners..hard)
nextttt (parts!)
--thanks to Bill Owen over at MNPCTech for some sweet UChannel
Update December 15/08 #1
heres some pics of the rig primed/painted. you'll see what happened
aandd....the trouble has arrived
after repriming/repainting the first time (gonna do it again after talking to balistx!)
anddd the case put together
gonna be redoing the removable mb plate and the 5.25' drive bay panels! wish me luck
Dec 15/08 Update #2
picked up some new parts.. you can see my experience over at the off topic forum.. but nonetheless parts are sweet
and some upclose of the peeling
I am always open to suggestions. If you have any input towards my build I'd love it! i know there are a lot of skilled rig builders here and wouldn't mind any input at all.
Feel free to post your comments!
Take it easy for now.
Old December 3, 2008, 08:40 PM
Default right on
wow man way to go.....
looking good so far just remember to keep all of the wires hidden so you get lots of air flow and it also makes it look nice.
a q6700 wow jumping up to us big dogs
when you want to over clock that send me a pm ill help ya out..
i am looking forward to seeing this build keep us updated..
if you need anything shot me a message on msn and ill try and track some goodies down for ya
CPU: Dual QX9775
MOBO:D5400xs
Ram: 4GB FB-Dimm
PSU:Koolance 1300 Watt
Graphics: Tri sli XXX GTX280 XXX
HDD:2 Supertalent SSD
LCD:24IN Samsung wide
CASE:TT Armor
Danger Den WC Setup
4 Pelts 226Watt
Old December 3, 2008, 09:31 PM
chouchou's Avatar
haha thanks reno
for sure i'll hit you up
sorry for the lack of updates.. waiting for some parts to come through.. went and bought a dremel the other day so i'll be making some cuts real soon
Old December 3, 2008, 10:15 PM
BALISTX's Avatar
Very nice man. Can't wait to see update.
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old December 9, 2008, 03:11 PM
really wanna see how the painting goes!
CPU:E8400 @ 3.8GHZ -->Zalman 9700NT HSF
GPU:XFX 5870 1GB
HDD:150GB Raptor,WD500GB,WD1TB BLACK
MOBO:Asus Striker 2 Formula
RAM:OCZ HPC REAPER 4GB 1066mhz pc2-8500 (5-5-5-15)@2.2v
PSU:CORSAIR 750W
CASE:Silvertstone TJ07
SOUND:Auzentech X-Fi Prelude
Keyboard:Logitech G15 V2
Mouse:Razer DeathAdder
Case Cooling:2x92mm exhaust,2x120mm exhaust, 2x120mm Ultra Kaze(3000RPM)intake.
Running:Win7 64-bit Ultimate
F@H PPD:46957
Old December 9, 2008, 03:54 PM
Babrbarossa's Avatar
Droool....tj-07
psst, wanna see my binder?
Old December 9, 2008, 04:11 PM
sswilson's Avatar
Great to see somebody who's got the patience to do the job right the first time.
Old December 10, 2008, 10:39 PM
chouchou's Avatar
Hey all! Update Dec 10/08. HAPPY BDAY MOM =]
Old December 10, 2008, 11:13 PM
lol my bdays on dec 10th as well
flooded with tests and assignments this week so no enjoyment =(
Intel Core 2 Duo e8400 @ 3.8GHz
Mushkin Ascent 1x2gb
Asus P5N-D
BFG Geforce 8800GT OC SLI (folding issues...)
WD 500GB
NZXT Apollo
OCZ Vendetta 2 w/ Bolt-thru kit +Scythe S-Flex F
Syncmaster T220, Razer Deathadder, Lycosa Mirror Edition, X-240 speakers
Old December 10, 2008, 11:15 PM
chouchou's Avatar
haha anywho happy bday bro.
get left for dead and game your way through xmas break :D
