  #41 (permalink)
Old August 6, 2007, 11:38 AM
sswilson's Avatar
Depends on how much time you have on your hands.... :)
Knowing for sure that the CPU OC is prime stable will point you directly to mem timings if it becomes unstable as you raise the mem divider.
  #42 (permalink)
Old August 6, 2007, 12:13 PM
BALISTX's Avatar
I was thinking once I get the mem divider to 3/04 which at my goal of 270 FSB will set my memory to 192MHz. In theory should my memory still be able to run at stock timing of 2-3-2-5?
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
  #43 (permalink)
Old August 6, 2007, 12:20 PM
sswilson's Avatar
Should be fine, but keep in mind that once you OC all bets are off as to what will and won't work well together.
Don't forget to keep your HTT (or is that HT? been a while since I played with A64s :) ) between 800 & 1000. As you go past HT of 250 you'll want to drop the multiplier down to 3.
  #44 (permalink)
Old August 6, 2007, 12:22 PM
BALISTX's Avatar
Drop the HTT multiplier or CPU multiplier?
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
  #45 (permalink)
Old August 6, 2007, 12:31 PM
sswilson's Avatar
HTT multiplier.
It works in conjunction with the HT (FSB) so your current setting of a 4 multiplier gives you 800 at stock (4 X 200). Once you get up to 250 - 260 you should drop the multi down to keep total HTT below 1000.
250 - 260 is a bit of a gray area as the 3X doesn't quite get you to 800 (3 X 260 = 780) but I always had better luck being a bit low rather than being a bit high.
It doesn't have much affect on performance, but can have a huge affect on stability.
  #46 (permalink)
Old August 6, 2007, 12:42 PM
BALISTX's Avatar
So in theory my final BIOS settings I should strive for.
FSB: 270
CPU Multi: 10x
HTT Mutli: 3x (810)
Mem Divider: 3/04
Mem Freq: 192MHz
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
  #47 (permalink)
Old August 6, 2007, 12:55 PM
sswilson's Avatar
I suspect that a 9 multi with higher HT might bring your mem closer to what it can run at, but what you've got for a plan is certainly a good starting point that you can try different combos from.
  #48 (permalink)
Old August 6, 2007, 01:39 PM
BALISTX's Avatar
Doing some calculating if I lower my CPU multi to 9 try to increase the FSB to 300 would give me 2700 MHz CPU speed and using the 3/4 mem divider would set my mem freq to 200 Mhz and my HTT x3 would be 900
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
  #49 (permalink)
Old August 6, 2007, 01:44 PM
sswilson's Avatar
Sounds perfect to me as a goal. :)
  #50 (permalink)
Old August 6, 2007, 01:49 PM
BALISTX's Avatar
That sounds like it would be my best option for everything to meet their optimal settings.
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Project: P190 MpG Case Mods, Worklog & Gallery 44 May 7, 2008 08:47 PM
My First Ever Water Cooling Project zlojack Water Cooling 37 February 6, 2008 08:10 AM
Large project James_8970 HTPC Systems & Software 6 January 9, 2008 09:44 PM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 12:08 AM
Project Darkside BALISTX Case Mods, Worklog & Gallery 44 October 14, 2007 06:44 PM
