  #41 (permalink)
Old October 2, 2008, 12:02 PM
Originally Posted by sswilson View Post
Do you have any fans ganged together on a single channel? The amperage on the NZXT is half of what it is on the Zalman. 4W vice 8.4 P=I X E with E=12V. .7a for the Zalman, .33a for the NZXT (assuming I've got my math right.... :) ).
i decided againt splicing fans the nzxt has 5 output for fans,dont need one on window fan,and have esa commander 01 will work with 780i mobo for any mobo/gpu fans
decisions,decisions i hate em..lol
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
  #42 (permalink)
Old October 2, 2008, 01:17 PM
Wonder how I missed this thread. Hey Jay paint came out well, get some more pics if you can, out of the 3, 2 of them were blurry.. idiot :P lol j/k..
I don't know what exactly you are looking for, but I've heard some good things about this NCIX.com - Buy Scythe Kaze Master 3.5IN Bay Fan Controller Backlit VFD Display Fan Temp Silver - KM01-3.5-SL In Canada...
Jay what exactly are you looking in that fan controller, that way I may be able to think of 1 or 2.
  #43 (permalink)
Old October 2, 2008, 01:47 PM
i just ordered the nzxt hopfully get PM.i like the auto set of nzxt,and shiny things.lol
better pics comming, just keep changing build..
  #44 (permalink)
Old October 2, 2008, 02:14 PM
Cptn Vortex's Avatar
That NZXT controller is neat, but it eats up alot of 5.25" bays!
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
  #45 (permalink)
Old October 2, 2008, 07:31 PM
well been benching my parts open air on my table last day or so ,i think im ready to OC now 780i/E8400/2x8800gtx/2x1gb 6400 crucial/freezer 7 pro
i oc 1 card to match the faster one 626/1000/1467,think i did that right.maybe previous owners can suggest a max for these gpu's approx.
cpu is e8400@stock,can anyone recommend any settings to get my oc started?
i was in bios for awhile did not get far tho.read to much ,now dont know where to begin.lol
what temp should i believe there all different
any advice greatly appreciated .
miggs pics coming as soon as i find camera,its here somwhere ,figured out the trick put camera down i shake to much..
  #46 (permalink)
Old October 2, 2008, 09:38 PM
SugarJ's Avatar
Upgrade Coretemp to 0.99.3 version, it has the correct TJmax value published by Intel in August. Then it will tell you the correct temps...
  #47 (permalink)
Old October 2, 2008, 09:43 PM
Sugar, use Realtemp or Coretemp, just set the Tjmax to 100 to give correct temps. It's just the adjustment.
  #48 (permalink)
Old October 2, 2008, 09:56 PM
SugarJ's Avatar
Ya, but I keep all my software up to date. Otherwise you may as well still be running Windows ME.
  #49 (permalink)
Old October 3, 2008, 11:26 AM
not sure what i did here, changed fsb so i thought.
just a bit then boot to XP cpu-z shows HT @1450.0mhz and only 2.1ghz for cpu
undid what i changed now sitting stock again,mem voltage i left@2.175 from 1.8 tho.
smoke break,time to put on me thinking hat,round 2 coming soon...will pc auto shut off before t blows up..
