Old September 14, 2008, 06:48 PM
sswilson's Avatar
Heh... I'm kinda wondering where the cat food (I'm guessing that's what it is) is going to fit into all of this..... :)
Looks like you've got everything you need, and are making plans to do it right. Let us know when you get that Apogee GT open if it ships with the "larger o-ring". At one time they said that they were going to put it in all of the new ones, but it seemed like quite some time afterwards we were still seeing kits that folks had to install it themselves.
(Don't forget to take lots of pics..... we need pics..... :) ).
Old September 14, 2008, 06:49 PM
sswilson's Avatar
Ummmmm you didn't forget the burner did you? (Don't see one in the pic).
Old September 14, 2008, 06:54 PM
was wondering who would be 1st to mention the catfood..bet my bro someone would.
already open ,what am i looking for?
it came with 2 rings 1 was installed,but i got curious ad opened the block..lol
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old September 14, 2008, 06:59 PM
nope i have a dvd burner :)
Old September 14, 2008, 07:00 PM
Cptn Vortex's Avatar
is the base of the block bowed? If so, the thicker oRing is installed. If the base is flat, then it is the thinner oring, and you should change it out with the spare.
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old September 14, 2008, 07:05 PM
Can u mount 2 dual rad on the side penal of the HAF?? Since it supports 4 * 120mm fans!
Old September 14, 2008, 07:06 PM
Infiniti's Avatar
You might actually be able to..
You'll just have a hard time getting the side panel off, especially if you didn't leave enough tubing.
Old September 14, 2008, 07:08 PM
its flat,and the spare does look bigger.
thanks for the tip guy's
  #19 (permalink)
Old September 14, 2008, 07:13 PM
thatd be insane...and apprently if u elevate the rad with longer screws on top, u could mount a QUAD up there. AND, u might be able to mount a Single in the bottom, beside the PSU, AND, mount another Dual in the front!
sry for hijacking ur thread jay
  #20 (permalink)
Old September 14, 2008, 07:14 PM
sswilson's Avatar
Just remember to practice your deep breathing exercises before you try to get it installed.... some folks seem to get it right away... took me an hour!!!!
