Old August 2, 2008, 08:02 PM
cyberspyder's Avatar
Level up: 3% Level up: 3% Level up: 3%
Level: 9 - 227 points to level up
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default Appraisal for A.C. Ryan AluBoxDuo LAN SATA
How much for one BNIB (Brand New In Box)?
Combine 2 harddisks!**
Create 1 big harddisk with 2 harddisks**
Break the Terra barrier affordably and easily**
Use as 2 harddisk or aggregated as 1**
Mount them as Mirror, Stripe / RAID 0, 1**
Up to 8 harddisk can be aggregated / mirrored / striped
Connect to PC via USB2.0
USB2.0 480mbps / compatible with USB1.1
The simplest and fastest way to get more harddisk onto your PC / notebook
Connect to directly to network via LAN 10/100
LAN 10/100mbps
Direct connection to LAN as network LANdisk
Direct access to your data anytime from any computer within your network
100% secure using NDAS technology without using IP addresses
Only user granted access can see the harddisk
For all 3.5" SATA/SATA2 harddisk
Use SATA/SATA2 harddisk
Supports all 3.5" harddisk up to 10000RPM
Supports all 3.5" harddisk up to 2TB (2048GB)
** NOTE : Retail Boxes & Catalogs nay still state 1024GB, but every AluBox, AluBoxDuo, AluBoxTFX, AluBoxValue already support up to 2TB (2048GB)
True HotSwap Plug-n-Play
Simply Plug n Play even while your system is on
Front BlueLED light indicates HDD activity
1.8mm solid aluminum
Keeps harddisk cool
Ultra lightweight solid construction
Shock resistance up to 90cm freefall
High quality mirror polish
Built-in fan
Keeps both harddisks cool
Horizontal Stackable or Vertical
Designed for horizontal or vertical placement
Multiple box can be stacked on each other
Thanks, Brendan
RIG: Intel C2D e7200, DFI DK P45 T2RS, 4GB G.Skill DDR2-1000, Gigabyte HD4850, 500GB Samsung, Pioneer SATA Burner, Antec SOLO, Corsair VX550
COOLING: Thermalright HR-01 PLUS, GFXChilla, 120/92/80mm San Aces, 40mm Scythe Kazes, Sunbeam Rheobus
PERIPHERALS: Logitech MX518, Logitech Wave, Steelpad QCK, Samsung 20"
AUDIO: Beyerdynamic DT770/80 (recabled), Ultimate Ears super.fi 3 (recabled), Zaph ZBM4, Audiotrak HD2, DIY ICs, JBL Power20
I BLEED TOXIC GREEN...find me on USN for gear-related Q's
Old August 3, 2008, 04:26 AM
sswilson's Avatar
Super Moderator
Positive Positive 1 1 1
Since it's BNIB, I'd check around to see what it would cost to buy locally (or get delivered) and offer it for 75% of the pre-tax cost.
Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW
ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF
Old August 4, 2008, 06:04 AM
low351's Avatar
Level up: 8% Level up: 8% Level up: 8%
Level: 10 - 260 points to level up
Default Watchout for NDAS and comparison.
Is it for purchase by you or sale?
You can get a W.D. My book world from costco for $539 with 2 x 1TB drives in it.
So figure $135 for a 1TB drive from CanadaDirect or other and you've got $270 from teh $539 so you've got $269 left.
So if the A.C. Ryan is $269 or less then it's a good buy. Only caveat is that it's an NDAS device. There are claims that an NDAS device is better than a run of the mill file sharing NAS device but, If you have any funky network softare on your PC like a VPN client it may conflict with the NDAS driver.
I had a user purchase an NDAS device and it wouldn't play nice with Check Point SecuRemote, the VPN client we use here at my Company.
LAPTOP (Internet Browser)
SONY VAIO CR520
1280x800 WideScreen (glossy)
Inte Core 2 Duo Penryn T8100 2.0Ghz
Intel X3100
3GB PC-5700
320GB
Old August 4, 2008, 09:49 AM
It's for sale by me. From what I've seen, it's about $139 at other places, so that might be a good starting point.
Thanks for the help guys.
