Old May 28, 2008, 01:47 PM
donimo's Avatar
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default FS/FT 2x Arctic Cooling Freezer 7 pro's and more
Hi, I have decided to build my PC I had for sale into an HTPC instead. The case I am using is about 3 pubes too short to allow me to use the AC7 pro cooler.
I would like to trade it for something that would fit, like a Scythe ninja mini, or a Shuriken, or anyhting else you have that would work.
I am using a stock C2D intel fan on a 520 prescott, and it hits 56-58*C whenever you tax it with HD vid, so... not working.
Also I am lookng for a video card to offload processing too, like an HD3450, to get the CPU load down from 70% with 1080p content, yipee
things I could trade are:
2x AC Freezer 7 pro's, Both are in as-new condition, upgraded to a TRUE on one PC, and I already told you about the other one.
ASUS TUV4X mobo with a Tualatin PIII-S 1266, was once a great processor, prolly make a good server board, ran Ubuntu with zero issues.
Delta Mini power supply, 20-pin 150W, great for a mini-pc for a car etc (5x4x2.5inches)
CD burner + cd drive
SB Audigy2 sound card, as new
Logitech Cordless optical trackman, used for a month, decided I don't like trackballs, was $100 new, still the current model sold.
ATEN video extender, run a second slave monitor up to 150m away, needed it for a specific situation that no longer exists, used maybe 6 months, was $300 last year.
I only have the one pic here at work will take more at home later:
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
