Old January 20, 2017, 06:22 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default FS: XL Single Stage rotary cooler, Fluke 51II, solid copper CPU pot, and alum GPU pot
Cooler was custom built for me by ruffus and has served me well. Has a 10,500btu rotary compressor and an XL condenser and cools below -50 in a few minutes. The gas is a customized mix of r410a and r22a and the cooler is designed for holding a 300W load at -30C. This is the largest and most powerful SS cooler that I have seen out there in OC land and it works great. Measures 35cmx35cmx52cm and it has a longer evap pipe so it will reach your hardware.
I am located in Calgary and I am looking to sell locally if possible because it is nearly 80 pounds and I would rather not ship it.
Asking $475 for the cooler + shipping
$70 shipped for the Fluke - SOLD
I am also selling a solid copper pot for CPU and a solid aluminum pot for GPU. Both come with mounting hardware and hold down as well as insulation.
The GPU pot I bought from a forum years ago and I honestly cant remember who made it. Probably someone here can identify. Comes with a built in temp probe.
The CPU pot I had made out of a massive chunk of copper from an electrical pole. It is machined out of solid copper and is not a pipe with a cap. It comes with an extender piece that I sometimes used for dice. Has a few machine marke from when it was made but they are only cosmetic. It is a hefty pot and the bottom part excl extender is 1.3 KG.
Prices:
CPU pot $160 shipped within Canada
GPU pot $100 shipped within Canada
I will knock a bit off for pick up in Calgary or for combined shipping.
Old January 20, 2017, 07:04 PM
KaptCrunch's Avatar
correction rufus of xtremesystems was the builder
Old January 20, 2017, 08:07 PM
Ozzfest05's Avatar
Ruffus built quality units and I believe this is under priced and over built .
If someone is looking to step into sub zero they should jump on this.
Old January 21, 2017, 06:02 AM
marc_0053's Avatar
Wow too bad you are in Calgary, i would have picked all of this up right now
Old January 21, 2017, 08:57 AM
KaptCrunch's Avatar
be about $220 ground
Old January 21, 2017, 01:37 PM
Dead Things's Avatar
I suppose this means you are officially taking your leave of the overclocking community, eh Eldonko? If that's truly the case, then I'm sorry to hear it.
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
Follow my benching, folding, mining and miscellaneous shenanigans @dt_oc
Old January 21, 2017, 09:38 PM
Eldonko's Avatar
Not at all. I just work a lot of hours and have a small business so my time is quite limited. I'm just getting out of extreme stuff is all. I'll be around.
Old January 22, 2017, 06:29 AM
hausner's Avatar
Great unit from ruffus.
Good luck with your sale man!
I wish you was local.
i7 6700K / Asus Z10L Pro Gaming/ Asus 1070 /Corsairs 16GB DDR4/ Samsung Pro SSDs/Enthoo Evolv mATX
Old January 22, 2017, 12:55 PM
Eldonko's Avatar
CPU and GPU pots added to post. I also have a ton of H2O gear that I will add later.
Old January 24, 2017, 08:22 AM
Eldonko's Avatar
Bump :)
Rotary phase cooler by ruffus Eldonko Water Cooling 34 May 28, 2010 08:25 AM
[WTB] 9600GT with a single-slot cooler Dead Things Buy/Sell & Trade 19 April 15, 2009 10:00 AM
Lian-Li Releases TR-5 Fan Controller/Thermometer MAC Press Releases & Tech News 0 July 4, 2008 06:53 PM
DV Hardware reviews the ThermoHawk 200 Touchless thermometer Babrbarossa Reviews & Articles from the Web 6 February 13, 2007 12:59 PM
