Old September 8, 2016, 01:46 PM
JD JD is offline
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default Heatkiller 3.0 CPU Block Conversion Kit
Anyone have the 1150/1155/1156 conversion kit for the Heatkiller 3.0 CPU blocks lying around that they don't need? Dazmode doesn't seem to carry them anymore and FrozenCPU wants $25USD.
Alternatively, anyone have a cheap CPU block that'll fit 1155 that they want to get rid of?
Old September 8, 2016, 06:30 PM
Pretty sure Frozen CPU is out of business as well
Old September 9, 2016, 03:00 AM
I think I might be able to accommodate your request. I just swapped over to the 2011 kit from my 1150 kit not too long ago. I just need to confirm all parts are there in the box.
Xeon 1660 ES V3 8c/16t @3.2Ghz
MSI X99S MPower
32GB Corsair LPX 2400 DDR4
Xfx R9 290X (x2) | Dell 2709W @1200p(left) Yamakasi Q270 Catleap 2b @1440p 120hz (Right) LG 4k w/Freesync (center)
Samsung 950 Pro m.2 @ Gen3 x4 32Gbps | Seagate 4Tb with 256 SSD cache
Corsair Obsidian 800D | Seasonic X-1250
HeatKiller 3.0 | EK R9 290x WB (x2) | TFC Exchanger Quad Rad |Thermochill PA120.3 rad|TFC Dual rad Scythe Gentle Typhoon (x9) |Swiftech MCP655 (x2) | Koolance bay Resevior
Old September 9, 2016, 08:53 AM
JD JD is offline
I really just need the brackets and the screws if they're different. If you have a spare allen key of the correct size, that would be nice too, but I'm sure I can find one of those elsewhere if not.
I have an EK backplate + mounting hardware that I had spares of, so I don't need the HK-specific mounting screws/pegs.
Old September 9, 2016, 01:43 PM
Ok, I just checked and I have all the parts including the backplate that was sold separately (why?), so no need to use EK parts. However, funny how you should mention allen key, I'm currently searching for those so I can take off the brackets that are still on the block as I retro'ed my original 1366 block which was better looking than the 1156 block. Even in my own tool box I don't have the correct sizes so I'm looking everywhere.
UPDATE: Found both allen keys to get the brackets off. JD sending you a PM.
MSI X99S MPower
SFF conversion MARSTG New Builds 14 January 20, 2016 05:51 PM
Using heatkiller back plate w/ EK universal GPU block Ichigo27 Water Cooling 2 October 28, 2013 08:07 PM
[FS] Watercool Heatkiller GPU-X3 GTX680 "Hole Edition" Full Coverage Water Block *NEW* Zer0 Buy/Sell & Trade 7 July 22, 2013 10:42 AM
[FS] (1 ITEM LEFT) Nvidia GTX5x0 HeatKiller GPU water block codeman Buy/Sell & Trade 5 March 18, 2012 08:22 AM
Conversion help The Quicken iPhone & iPods 1 March 16, 2011 07:58 AM
