Old August 13, 2014, 07:26 AM
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default WATERCOOLING COMBO 2x240mm thick rad, D5 vario/res, EK supremacy
All fittings 3/8ID 1/2OD: 120$
6x straight compressions
5x 90 deg compressions
4x 45 deg compressions
3 x 90 deg adaptors
1x in-line ball valve
1x T-splitter
1x banjo fitting
3x 1cm extenders
1x 2cm extenders
2x M-M rotary adaptor
2x bitspower M-F rotary adaptor
1x M-M short adaptor (sli nipple?)
2x 30 deg bitspower adaptor
2x PAIRS of Koolance QD3 quick disconnect cost $60+ alone (newest series, one is abit tight to put on and release)
Pump Res Top: $120$
Koolance PMP-450/S, Rev.2.1 top
Bitspower Multi Z-150 reservoir
Swiftech D5 vario with sleeved red and black
EK D5 X-top V2 acetal top
CPU block: 60$
EK supremacy CSQ plexi nickel, plexi is polished following lowfats guide on OCN, turned out pretty good. No corrosion/gunk
Radiator: 100$
XSPC RX240 (some bent fins none that are damaged) 60mm thick rad
Alphacool NexXxoS UT60 multiport 240mm (no bent fins) 60mm thick rad
Freebies if combo purchased: value around 40$
2x Cougar 3pin black fans
2x Bitfenix Spectre 3pin black case fans
some koolance clear tube
some neoprene black tubes
deluxe hose cutter
ran with distilled water
Price breakdown is marked beside the sections
120mm rad in pic is not included, and ut60 rad is included but not shown in pic
prefer not to partout thus taking 100$ off the total Asking combo total $350 + shipping or picked up Waterloo
Old August 13, 2014, 09:08 AM
How much for the D5 pump and EK pump top?
Old August 13, 2014, 09:34 AM
fishingfanatic's Avatar
Smile BST
Man wher were you yesterday when I ordered from Daz...
Timing... glwts
FF
Old August 15, 2014, 06:54 AM
ttttt
[FS] GSkill DDR3 RAM 1600Mhz - Two different set's and PWM GentleTyphoon AP29's Nightingale Buy/Sell & Trade 16 January 14, 2018 03:28 AM
[WTB] looking for a EK supremacy naked ivy mount kit cennis Buy/Sell & Trade 1 August 6, 2014 08:17 PM
D5 Vario part number Dazmode Water Cooling 3 May 19, 2011 07:57 AM
[FS] triple 120mm watercooling radiator, 1.25" thick (Black Ice Extreme ll) elninio Buy/Sell & Trade 0 November 28, 2010 03:36 PM
[WTB] Thermochill PA.120.3 (15mm) and 655/D5 Vario pump Apollo4g Buy/Sell & Trade 1 January 22, 2010 08:56 AM
