Old June 5, 2014, 01:50 PM
JoeOnePack's Avatar
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default *$895* Custom Bitfenix Prodigy M-ATX (3770k, 240GB SSD, Maximus V, R9 290) XFX 7970
Custom Prodigy M-ATX PC (3770k, 240GB SSD, Maximus V, R9 290)
I completely modded the original Bitfenix Prodigy ITX case into an M-ATX case using the motherboard tray from a Fractal Core 1000. This is THE MOST compact M-ATX, dual GPU case on the market. The IO side panel has a cutout for a fan controller. The only downside is the front panel has the two top clips broken off. It still attaches to the case though. The case will come with a Bitfenix Windowed Side Panel.
Parts are as followed:
CPU - i7 3770k 3.4Ghz
RAM - 2 x 4GB Corsair Dominator 2000Mhz
GPU - Gigabyte R9 290 4GB
Mobo - Asus Maximus V Gene M-ATX
HDD - Crucial M4 240GB SSD
PSU - Corsair AX860
Cooler - Corsair H100i w/ Corsair PWM Fans
Front Fans - 2 x Corsair SP120's
Rear Fans - Arctic Cooling F8 80mm Fans
Custom Cool White LED Strip to 3Pin Header
Chrome Case Feet
XFX 7970 Black Edition Reference Card - $125
These are Voltage Unlocked. I bought these from a godlike member of the Dazmode forums with the intention to watercool them, but plans changed.
These cards need new thermal pads so the cooler can seat properly on the cards. Cards were tested before purchase so, I know they work. They have been sitting in the box ever since I bought them. These would make fantastic water cooling cards. This card was NOT used for mining. Comes with box, manual, Crossfire Bridge and Anti-Static bag.
Sennheiser / Asus Xense PC350 Headset - $99
Headset is in mint condition. Big improvement in sound over stock PC350's. Great situational awareness and overall good sound quality.
Asus VE247H Monitor - $99
Great condition monitor. No scratches on the screen. No dead pixels. Both monitors have been debezeled, but put back to stock. A couple clips broken, but fully functional. Missing the two stand screws.
Gigabyte Windforce 560TI - $45
Mint condition. Used in my second computer. Purs like a kitten.
Alphacool ST30 340 Radiator - $35
Radiator is in new condition. Not a scratch on it. Comes with complete factory hardware and original box.
XSPC EX240 Style Radiator - $20
Up for sale is a XSPC style generic 240 radiator. Condition is great. A couple bent fins and a few scratches, but works flawlessly.
Razer Blackwidow Ultimate Battlefield 3 Edition - $50
Excellent condition. Works like new.
Steelseries 6GV2 Keyboard - $45
Mechanical keyboard. Highly sought after. Mint condition.
Razer Deathadder Mouse - $20
Excellent condition mouse. Blue colour. Works like new.
Open Air Aluminum Mining Frame - $20
Made this myself. Using Aluminum Tube and Aluminum Angle. Standoffs are plastic spacers. Super sturdy.
4 x 16x Unpowered Risers - $3 ea (4 available)
Never used. Solid construction. Nothing more to say.
[B]XFX 7970 Black Edition Reference Card - $125 (1 Left)
Acer Aspire One Netbook AO725-0691 - SOLD
Excellent condition. Comes with HDMI and USB 3.0. A couple rubber feet missing on it. Otherwise mint.
Scythe Kazemaster II Fan Controller - SOLD
Mint condition. Changed controllers. My loss is your gain.
XSPC RX360 Radiator - SOLD
Up for sale is a mint condition XSPC RX 360 Radiator. This is an extra thick radiator. Fins are in 100% condition. Looks brand new. Only mounted to test fit. Too big for my case. My loss is your gain.
Sells for over $100 + tax, if you can find one.
Samsung U28D590D 28" 4K Monitor - SOLD
Up for sale is a Samsung U28D590D 28" 4K monitor. Its in mint condition. No dead pixels whatsoever. Screen is gorgeous. I'm moving and traveling soon and don't have room to hold onto it for the time being so it has to go.
Comes with box and accessories. Sells for $678 w/ tax.
Corsair AX850 Gold Rated PSU - SOLD
Excellent condition. Comes with box and accessories.
Shimian 27" 2560x1440P IPS Monitor - SOLD
Excellent condition. Tempered glass front. No dead pixels as far as I can tell. A couple specks of dust between the glass and screen. Can be cleaned. Otherwise minty fresh. Comes with Power cable and DVI.
Bitfenix Recon Fan Controller - SOLD
Mint condition. Changed controllers My loss is your gain.
Asus P8H61-I Motherboard - SOLD
Used in my old build. I believe the PCI slot went. Perfect for an HTPC build.
Bitspower Multi-Z 150 Reservoir - SOLD
Was going to use in my WC build. Decided to change plans. Excellent condition.
Custom Gaming PC - SOLD
CPU - I5 3570K
Mobo - Asus P8Z77-M
RAM - Kingston 2x4GB HyperX
GPU - Asus 650TI Boost 2GB
PSU - Corsair CX500
HDD - 2.5" WD 450GB 7200RPM
Case - Cooler Master N200
Fans - 3 x Yate Loon Blue LED, 1 CM Fan
Cables - Dazmode Blue CPU, 6Pin PCIE & 24Pin ATX Extension Cables
Samsung 1TB 7200RPM HDD - SOLD
Used in my last build. Works great. I don't have room for it anymore, so it has to go. Top sticker painted black
Kingston 2x2GB 4GB 1333Mhz RAM - SOLD
Used in my old build. Upgraded, so my loss is your gain.
Sapphire 6950's - SOLD
Never mined on. Just sat. Mint condition. Bought from someone who X-fired them.
Sapphire 290X Tri-X OC 4GB GPU - SOLD
This card is considered the best 290X you can get. Based on a reference design, voltage is unlocked. The cooler on this card is a beast. Looking for a reference 290X to trade for + cash.
Comes with original box, accessories and warranty receipt.
Corsair C70 Case Gunmetal Black - $SOLD
This case is in excellent condition. Was going to use it for my project. The 5.25 bay was taken out and there is a small hole where the Front Panel connector is for a cleaner look. Otherwise in mint condition. I can rivet the 5.25 bay back in for you if you wish.
Corsair HX650 Gold Rated PSU - $SOLD
Excellent condition. Comes with most if not all original cables and box.
OCZ 1000W Z Series Gold Rated PSU - SOLD
One of the most efficient PSU's in it's class according to Johnny Guru. Mint condition. No box.
Gigabyte 990FXA-UD3 - SOLD
Excellent condition board. Was going to use to mine, but never did. Missing IO plate.
Gigabyte 990FXA-UD7 - SOLD
Like new condition. Was going to use to mine, but never did.
Corsair Vengeance 2x4GB 1600Mhz RAM - SOLD
Mint condition. Used in my last build. Switched to something else.
Old June 5, 2014, 11:54 PM
PM'd about your 7970
Old June 9, 2014, 05:46 PM
JoeOnePack's Avatar
Bumps!
Old June 11, 2014, 04:53 AM
JoeOnePack's Avatar
bumps
Old June 12, 2014, 03:08 PM
JoeOnePack's Avatar
Price Drop!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old June 12, 2014, 11:00 PM
Damn it, should have saved for the 290x :P
Old June 13, 2014, 12:09 AM
JoeOnePack's Avatar
PM'd.
Old June 17, 2014, 11:13 AM
JoeOnePack's Avatar
bumps
Old June 26, 2014, 08:18 PM
JoeOnePack's Avatar
bumps
Old July 7, 2014, 08:05 PM
JoeOnePack's Avatar
NEW STUFF ADDED!
Need Help: Litecoin Mining with Win8.1, 6950 Masteroderus Video Cards 1 February 25, 2014 07:27 PM
[WTB] Intel 3770k, Good 1155 Mobo, Radeon 7970 or Similar. Uberg33k Buy/Sell & Trade 0 February 4, 2014 09:32 AM
7970 + 6950= gaming bliss? HoserEh Video Cards 9 December 5, 2012 09:08 AM
Suggest Me a Mobo - 670/7970 icu222much CPU's and Motherboards 3 November 23, 2012 09:56 PM
