Old April 11, 2014, 12:35 AM
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default *UPDATE* Wanted: cooler Master vertical gpu mount and riser cable
Hey guys is ma looking for the following item or something similar...
Message me if you have e something like this
Old April 14, 2014, 07:20 AM
Bumps
Old May 15, 2014, 09:41 AM
Bump for new content
Old May 17, 2014, 07:14 AM
Bump :P
Old May 21, 2014, 05:08 PM
Bump :p
Old May 26, 2014, 07:59 PM
Bump still looking....
Old May 26, 2014, 08:37 PM
Cptn Vortex's Avatar
Any interest in upgrading motherboard... I've got a Intel 5400 series chipset board collecting dust. Uses the same Ram, supports Xeon 54xx series procs. Wont fit in the Mac Pro chassis, but gives you more processor options. Should still work with Mac OS as its basically the 2008 Mac Pro setup.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 670 FTW
8GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
Lenovo P24q 24" IPS 2560x1440
Benq W1070 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block x 2, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old May 27, 2014, 04:08 PM
3.0charlie's Avatar
Too bad it ain't a 5500 series board, I have twin X5560s with a fair amount of dust on 'em...
Hydro-Quebec is salivating...
Old May 28, 2014, 10:50 PM
Edits
Old June 1, 2014, 01:08 AM
And....... Bump
Tags
acrylic , bending , mandrels , monsoon
monsoon fitting problems marquee Water Cooling 1 June 3, 2013 06:09 PM
Monsoon compression fittings Keywork Water Cooling 11 February 12, 2012 01:15 PM
WB causing GPU to bend tragd Water Cooling 9 October 11, 2010 01:39 PM
Toshiba's Bend-to-Zoom LCD [toms] I Know but cool gingerbee Press Releases & Tech News 3 June 3, 2010 02:39 PM
