Old November 23, 2012, 09:18 PM
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default i7 combos, Hard drives, Video Cards, RAM, sound card, AM2 CPUs
Local pickup is preferred.
Payment method:
Cash for local, EMT for shipping.
Shipping is through Canada Post; typical rate is $15 across Canada.
Oversized / multiple items may have a different rate or not shipped at all.
COMBOS
i7 LGA1150 - MB/CPU/HEATSINK - $500
CPU: i7-4790k - $400
Motherboard: Gigabyte GA-Z87X-UD3H - $120
Heatsink: CM Hyper 212 EVO - $20
Notes: All original boxes and accessories included. Everything has 2+ years MFR warranty.
Runs stable; has never been overclocked.
i7 LGA1156 - MB/CPU/HEATSINK/RAM/Expansion cards - $300
CPU: i7-860
Motherboard: Intel DP55WG (only io shield included)
Heatsink: CoolerMaster Hyper 212
RAM: Corsair XMS3 2x2GB DDR3-1600 9-9-9-24 1.65v - $40
USB 3 expansion card: Silverstone EC04 - PCIe - 2 external ports & 1 internal header - requires 4pin molex.
SATA 6Gb/s expansion card: Silverstone EC05 - PCIe - 2 internal sata 6 ports.
Notes: No original boxes or accessories unless otherwise noted. No MFR warranty on parts except RAM (lifetime MFR warranty.)
Hackintosh compatible; tested up to 10.9. Runs stable, currently in use as a dual-boot workstation. Has never been overclocked.
Not parting out, except for the RAM.
Hard drives
ST3000DM001 - Seagate 3TB - $90 each / 4 for $300
Note: All drives have been tested thoroughly (all Seatools tests) and securely wiped.
Upgraded to 4TB drives, no longer need 3TB.
Video cards
HIS R9 270x 2GB - IceQX2 - $160 ~2 years warranty left.
Gigabyte GTX 550ti 1GB - $50 No boxes, accessories or warranty, just bubblewrapped. Used for hackintosh, compatible OOB with 10.8.5 Mountain Lion.
Take both cards for $180
RAM
Note:
All memory has been thoroughly tested with HCI Memtest Pro.
DDR3
Corsair XMS3 2x2GB DDR3-1600 9-9-9-24 1.65v - $40 (Lifetime MFR warranty)
Various OEM value RAM - 2GB sticks - DDR3-1333 1.5v - $20 each
Sound card
HT OMEGA Striker - PCI - $20
AM2 CPUs
Phenom x4 9500
Athlon x2 4400
Athlon x2 3800
all for $20 / Free with purchase over $60
*********SOLD********
i7-4770k
DDR2
GSKILL 2x2GB DDR2-1000 5-5-5-15 2.0-2.1v - $30 (Lifetime MFR warranty)
Asus DirectCU2 7870 - 1ghz edition - $140
Gigabyte Windforce 7870 - 1.1ghz OC edition - $140
Sealed i7-3930k LGA2011 6 cores / 12 threads - $400
Asus Xonar DX pcie sound card - $40
Zotac GTX 560 - $60
2+ years warranty through manufacturer.
original box accessories
LGA1155 i3-2120 CPU & Gigabyte B75M-D3H mobo
$130
Includes all original accessories and boxes. 2 year manufacturer warranty left on each item.
Corsair TX750M modular 750w power supply $80
Comes with original box, all the cables, accessories, etc. Was purchased in August and rarely used.
1 x WD Black
1 x Seagate 7200.12
Gskill 2x2GB DDR2-1000 5-5-5-15 2.0-2.1v $30
Motherboard, CPU, RAM, Case, PSU, Heatsink, SSD: $140
Biostar I45 LGA775 motherboard, E5200 CPU, G.Skill DDR2-1000 2x2GB, Coolermaster CM690 /w additional drive bay (holds 9 HDDs total), Corsair CX400W, Xigmatek HDT, Kingston 64GB SSD
2TB HDDs: $50 each
2 x Seagate LP ~5400RPM
2 x Hitachi 7200RPM
XFX Radeon 6870 $120
Comes with original box, accessories, etc. I can transfer the lifetime warranty over to you. Rarely used.
Syba pci-e1x 2 port SATA cards $20 for both
Bootable, supports RAID 1 & 0
1TB HDDs: $30 each
3 x Seagate 7200.12
Seagate 7200.10 250GB HDD $5
LCD desk mount $15
All original stuff included, barely used. Didn't fit my desk and it's not worth returning.
Intel Gigabit PT PCI-e NIC $30
4 x 512mb ddr2-667 Free with purchase of another item.
Thomson Speedtouch 516 DSL modem ST516 V6 $10
Comes with power adapter and rj11/phone cable.
2 x XFX Radeon 4770 $40 each or both for $70
HIS Radeon 4830 $35
XFX Radeon 4830 $35
Get both 4830s for $60
BNIB Antec Kuhler 620 liquid cooler - $30
Opened to get at UPC for MIR. Heatsink itself is unused.
Powered PCIe x1 to x16 risers - $20 each (5 available)
These are the non-ribbon versions, the USB cable is strictly for data between the riser pieces.
Comes with molex to sata adapter (you can use either molex or sata from your PSU to power it).
Intel LGA1366 DX58SO Motherboard /w 3x2GB Corsair Platinum Series RAM 1333 9-9-9-24 $120
Motherboard comes in original box with all accessories, etc. Rarely used; purchased as a backup board when while my other board was in RMA. Have since sold my 1366 system. RAM is just in a ziploc bag in the motherboard box.
LCD desk mount $10
For only $15.51 each when QTY 50+ purchased - 2 Way Adjustable Tilting Desk Mount Bracket for LCD LED (Max 33Lbs, 13~30inch) - Black | LCD Desk Mount Brackets
My desk is cheap and weak, this thing requires a sturdy desk to mount properly, or it will wobble.
Old November 30, 2012, 08:16 AM
Trial Member
ygpm for the WD 1TB
Old December 5, 2012, 07:03 AM
Trial Member
Is your file server sold ?
Old December 27, 2012, 06:23 PM
Your_friendly_gamer's Avatar
great seller, free bump
Old January 12, 2013, 03:19 PM
Astaroth's Avatar
You got private message
Old January 13, 2013, 08:39 PM
Astaroth's Avatar
Bump. Thanks for the PSU
Old June 12, 2013, 05:10 PM
PMed about the chair
Old July 10, 2013, 12:08 PM
sswilson's Avatar
Cleaned up your thread a bit by deleting your old bump posts.
Wish I was local... I'd buy up that striker in a second. :)
Gigabyte Z97N-WIFI / i7 4770K / 2X 8G Gskill 1866 Sniper / XFX XTR 750 / EVGA GTX 970 SSC ACX 2.0+
Corsair 380T / Corsair H100i GTX AIO/ Intel 730 Series 480GB SSD / Seagate Barracuda 1TB / Dell UltraSharp U2412M
Asrock AM1H-ITX / AM1 Athlon 5350 / 2X4G Gskill PC3-14900 / Intel 6235 Wi-Fi / 90W Targus Power Brick / 250G Samsung 840 Series SSD / Mini-Box M350 / 24" Westinghouse L2410NM
Old July 10, 2013, 12:47 PM
KaptCrunch's Avatar
any pic of the seal on i7-3930K for BNIB means seal is broken
should read Sealed Box then no question cpu is virgin
Old August 4, 2013, 11:43 PM
YHPM
monitor stand *Z2 Desk Mount* clshades Display Units 1 January 18, 2013 08:51 PM
Motherboard and Power Supply antoniof68787 CPU's and Motherboards 0 July 13, 2011 07:35 PM
[WTB] LGA 1156 Processor, P55 Motherboard, HD5770, Hard Drive, Memory, Power Supply + More Yamcha Buy/Sell & Trade 1 August 23, 2010 02:59 PM
Power Supply and Fans Charmster Power Supplies 3 June 18, 2010 10:48 AM
Motherboard or Power Supply enaberif Troubleshooting 1 September 12, 2007 05:37 AM
