<~----> Want to Buy Router or Decent Wifi Card/Dongle - Page 2 - Hardware Canucks
Old December 6, 2012, 03:29 AM
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Originally Posted by igot6strings View Post
WTB:
Wanting to upgrade my sons computer a bit. Hes only 4 so all he needs is a smooth running minecraft for the time being. Currently has an Athlon X2 64 4600, 2gb ddr2 667mhz and a Radeon 6450. I'd be looking for a Athlon X2 64 5800ish cpu, a video card up to a 5770/6770 or the nvidia counterpart. Also want to find him as much ram as possible so 4x2gb of DDR2 800mhz.
I'll consider anything better than whats in there now.
pm details/price. ty
Sorry I have nothing to offer, but what motherboard do you have? It may be able to take a newer processor that would be easier to get your hands on.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old December 7, 2012, 07:16 AM
Hey, its a Asus M2N-VM DVI.
ASUS - Motherboards- ASUS M2N-VM DVI
I've seen several 5600 and 5800s on ebay for $20-35 but they're mostly in Asia but I'd prefer to buy something a little closer to home. I see theres all sorts of different cpus compatible with this board on the page so I'm not sure what is the best and easy enough to find. I'm open to suggestions of course. Not really looking to spend a fortune on this either.
Old December 7, 2012, 09:54 AM
My experience with the old x2 6000, 5600 and 3600 it would be a waste of $20-30 going up from a 4600.
More $$ on ram no point, 4GB would be fine unless your 4 yr old requires 8GB for specific programs.
I've watched this thread for a couple days now and figured I'll put my 2 cents in, try to aim for cheap 6770/6850/7770, solid psu to move to another build (if you don't already have one) and an ssd.
Where the mobo falls down is that the mobo doesn't support the x3 and x4 propus cores some am2 boards do, x3 450 or x4 640 would be a worth while upgrade.
Sorry I have nothing for you but free advice.
x4 965BE 3.7ghz / Tuniq Tower 120/ xfire HD6870s / 4x2GB G.skill/ S12D 850w/ Ga Ma 790X-UD4/WD640AALS Black x2, WD1TB FALS x1, Seagate 250GB x1/ BenQ 21.5" 1920x1080/ Win 7 64
Old December 7, 2012, 10:25 AM
Cool. Thanks for the advice.
He only has 2gb in there now, it was 4gb but 2gb failed sometime while it was sitting in the basement collecting dust.
I'd be happy if he had 4gb in there again.
A 6850 would be overkilll for his needs. I think a 6770 or something similar would be best and also not require upgrading the psu.
It actually runs minecraft fine at lower settings with his system oc'd to 3.0ghz.
I'm hoping to be able to upgrade atleast 2 out of 3 of the parts I'm asking for. If I can do that then I think his system will run just fine until he gets my wifes q8200 as a hand me down when I upgrade hers.
Old December 11, 2012, 12:31 PM
still looking for the above or similar.
Old December 19, 2012, 03:17 AM
nothing yet. bumpage.
Old December 20, 2012, 01:33 AM
i have 4*2gb stick gskill lying around... however I just moved so I will need to locate them.
Old December 20, 2012, 10:55 AM
sure thing. pm me when you're unpacked and give me some details/price please. thanks
  #19 (permalink)
Old December 20, 2012, 11:25 AM
great_big_abyss's Avatar
You know, I'm wondering if you may be better off just changing platform altogether. AMD has some very affordable Athlon II platforms...
MSI 760GM-P23 - $54.99
Kingston 2x4GB 1600MHZ DDR3 RAM - $34.99
AMD Athlon II X4 640 Quad Core Processor - $69.99
Total: $159.97 + taxes/delivery.
You'd get a pretty major bump in performance over your old X2, and all for less money than you can spend on a new APU. You could then look for a used video card on the forums, or even go for:
ASUS Radeon HD7750 V2 - $112.99
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; ASUS GTX650Ti Boost; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; Sapphire HD5870; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
  #20 (permalink)
Old December 20, 2012, 11:36 AM
I'm only looking to spend $50-60 in total to upgrade this as he'll get my wifes q8200 system in a few months when I upgrade hers. Her new system will most likely end up being something from AMD though.
[WTB] Super cheap GPU for DIII and DDR3 2x4GB Soullessone21 Buy/Sell & Trade 7 September 30, 2012 08:15 PM
Vengeance 8GB 2X4GB DDR3-1600 CL9 foredown Price Check 2 March 20, 2012 06:09 PM
[WTB] Ripjaw-x 1600cl7 2x4gb jibz Buy/Sell & Trade 3 December 25, 2011 01:08 PM
[WTB] 8GB ( 2x4GB ) DDR2 RAM kit oblisk Buy/Sell & Trade 1 September 13, 2011 08:56 PM
2x4GB... Am I missing something? Spblue RAM 7 February 1, 2010 11:11 PM
