  #21 (permalink)
Old May 19, 2008, 03:51 PM
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Originally Posted by matsta31 View Post
Is it wide enough for 2 times 3x120 mm rad ?
no.
  #22 (permalink)
Old May 19, 2008, 04:40 PM
matsta31's Avatar
In there you got a 3*120 mm rad plus a 2 X120 ? So I guess this mean I could not install a 3*120 mm in its place ? I tought this box was square.
  #23 (permalink)
Old May 19, 2008, 05:29 PM
the box is quare, but on the bottom in the back, there is a 2nd psu spot instead of a 3rd fan spot. you could probably mount a 120.3 rad there, but it will be half assed around the psu spot.
  #24 (permalink)
Old May 19, 2008, 05:44 PM
Apollo4g's Avatar
Yup ive mounted a 3x120mm rad at the back with the PSU cover off. So yes if you wanted you could mount 2 x 360 rads in there.
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
