Old October 1, 2012, 01:34 PM
Alpine's Avatar
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default Eaton PW9130L2000T-XL 1800W 120V 2000VA TOWER UPS
Hello guys:
I have two (2) Eaton UPS 1800 watts 120 volts (2008) for sell. They are use and still working well.
Cash if local Paypal GIFT only if shipping.
I would prefer local deal.
Shipping on your cost and will be expensive. this weigth 75lbs each.
Asking price: 350$ each.
Here more info:
General
Topology Online, double-conversion
Catalog Number PW9130L2000T-XL
Color Black
Rating (VA/Watts) 2000/1800
Diagnostics Full system self-test
Efficiency >95% in high-efficiency mode; >86% in online mode
UPS Bypass Automatic bypass
Dimensions (H x W x D, inches) 12.8 x 8.4 x 16.2
Weight (lbs) 77.2
Warranty 30 DAY FROM SELLER
Contents
(Ships with the following items) 1 ready-to-go UPS
Intelligent Power Software Suite CD: (Intelligent Power Manager, Intelligent Power Protector, Network Shutdown Module, LanSafe and Personal Solution-Pac)
USB Cable
User Guide
Quick Start Instructions
Cord-Retention Brackets
Electrical Input
Connection 5-20P
Input Cord 6 ft line cord
Input Voltage Range 90-138 Vac
Nominal Voltage 120 VAC
Frequency 50/60 Hz
Frequency Range 45–65 Hz
Nominal Current 16.6 A
Breaker Ratings 20A
Electrical Output
Output Receptacles (4) 5-20R, (1) L5-20R
On Utility Voltage Regulation ±3% of nominal
On Battery Voltage Regulation ±3% of nominal
Voltage Wave Shape (On Battery) Sine wave
Power Factor 0.9
Frequency Regulation ±3% Hz online
Load Crest Factor 3 to 1
Load Segments Two configurable, individually controlled receptacles
Thank you
• ► › I7 3930K|Asus P9X79 WS|Evga GTX 690 Signature|Corsair Force 3 120GB|Corsair H1000|Corsair Dominator Platinium 16GB 2133Mhz|
Corsair AX1200|Corsair 600T SE|Corsair SP2500|Corsair Vengeance 2000
• ► › I7 2600K @ 4.9Ghz|P67A-UD4-B3|12G G.Skill 1600Mhz|Noctua NH-D14|OCZ Vertex 2 60GB|EVGA GTX 580 SSC|Corsair AX650|Lancool PC-K62|
Old October 3, 2012, 12:29 PM
Alpine's Avatar
Buump
Old October 6, 2012, 04:31 PM
Alpine's Avatar
buump
Old October 6, 2012, 06:56 PM
KaptCrunch's Avatar
good unit, how are the battery/s condition if need replacing you can remove them and shipping unit will be cheaper
Old October 7, 2012, 11:05 AM
Alpine's Avatar
Hello Kapt:
The battery have a 5 years of life. Now, they have been uses for 3 years, so battery have still have 2 years to give. Battery can be also changed when they die, but i don't know how much cost new one.
Old October 11, 2012, 07:14 AM
Alpine's Avatar
somewhere to the top
Old October 15, 2012, 12:09 PM
Alpine's Avatar
Last bump...... will remove this from the sale soon if no one need that.
Shooting in Eaton Centre Prolab Off Topic 3 June 8, 2012 06:31 PM
DD Tower 26 shelfelf Cases 4 April 27, 2012 10:59 AM
G-20 Retail Rage - Eaton Centre Toronto, ON Eagle Eye Off Topic 9 July 1, 2010 07:45 AM
120v outlet filter for noise, such a thing? (popping noise from speakers) On2wheels Troubleshooting 3 June 20, 2010 08:06 PM
120V pump to on/off switch elninio Water Cooling 2 August 24, 2008 08:40 AM
