Old June 18, 2012, 12:49 PM
Soullessone21's Avatar
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default G34 Mobo DEAD need to make a mount
Tons of people are asking for some water blocks I have and I want to know if anyone has a dead G34 mobo they want to send my way... That way I can confirm the blocks fit and if they dont, have my buddies at the machine shop on my road make me some brackets so they will :)
Good Bye HWC it was great :)
Site and Forum:
http://forums.realhardwarereviews.com/index.php
If you need me the link above is where I spend my days now
Old June 18, 2012, 01:28 PM
dandelioneater's Avatar
The bolt spacing for the G34 socket is 4.1". So as long as the plate was not too much wider than the block itself, I'm sure it would work.
Old June 18, 2012, 01:32 PM
Tim_H's Avatar
looking at your build with the C32 mounts it isn't going to fit. The mounting for the C32's are at 3.5" where the mounting for G34 heatsinks is 4.1"
Old June 18, 2012, 01:35 PM
So what I'm hearing is I really need a G34 board to make a bracket :P
Site and Forum:
Old June 18, 2012, 01:57 PM
Tim_H's Avatar
kinda, not really. the mounting holes are in a straight line 4.1" apart, so you should be able to get a bracket made that has the water block centered between mounting holes that are 4.1" apart.
like you say though it wouldn't hurt to use the board just to confirm.
[WTB] Looking for dead AMD mobo clshades Buy/Sell & Trade 2 January 23, 2012 08:57 PM
top mount- bottom mount - does it make a difference? johnnyblazzwa Power Supplies 5 December 20, 2009 09:13 PM
Dead Mobo Arinoth Troubleshooting 3 August 2, 2009 07:20 PM
LF: AM2 plastic fan mount for an ASUS mobo. Skyllz Buy/Sell & Trade 10 October 10, 2008 04:18 PM
Trying to make a mobo choice... Rausch CPU's and Motherboards 10 February 6, 2008 07:05 PM
