Old March 19, 2008, 02:38 PM
CMetaphor's Avatar
Level up: 60% Level up: 60% Level up: 60%
Level: 15 - 261 points to level up
Recent iTrader Ratings
Positive Positive 3 3 3
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Well.... since almost no one is interested anyways i guess it doesnt matter. Haven't heard back from Rapid-x in two days... So everything is probably still available.... Sigh
Current System: "Gale Force" (09-28-2008)
AMD X2 6000+ w/ TRUE (2x Scythe 120mm) | Asus Crosshair MB | 4Gb OCZ Plat.Rev.2 PC-6400 RAM w/ Corsair Memory Cooler | VisionTek 4870X2 2gig| Coolermaster CM Stacker 832 w/ 7x 120mm Fans (2x Tricool, 5x CM), 1x 80mm CM, and 1x Antec "Big Boy" 200mm Tricool Fan | Silverstone Strider 1Kw PSU | Seagate Barracuda 7200.11 500gig x 4 (Raid 1 & Raid 0)| 3x BenQ FP222w 22' Wide 5ms LCD Monitor & Matrox Triplhead2Go DE
Next system? Who knows...
Old March 19, 2008, 03:16 PM
3.0charlie's Avatar
Positive Positive 22 22 22
Originally Posted by Jmac View Post
Every amplifier is designed differently and the owner's manual will tell you the minimum supported impedance. This particular amplifier is not designed for 1 ohm loads, most likely because the wiring and/or circuit board are not designed to handle the current a 1 ohm load would require.
Also, halving the impedance doesn't double the output. As stated in the previous paragraph, the amplifier probably won't be able to handle the additional current meaning that there will most likely severe losses as the internal resistance increases due to heat, the distortion will rise as the load drops, and it will severely shorten the lifespan of the amplifier. What you're suggesting is very likely to destroy the equipment.
In addition, a pair of dual 2 ohm subs can be wired to 0.5 (parallel-parallel), 2 (parallel-series or series-parallel), or 8 ohms (series-series). Wiring them in parallel-parallel would either throw the amplifier immediately into protection mode or damage the amplifier.
Sorry to thread dump, I just don't want anyone to buy the stuff then destroy it and blame the seller.
Did you read what I wrote?
FYI a class D amp is best driven at 1 ohm impedence. With both 15 inchers at 2 ohm, wire them both to the amp in Parallel, to drop the impedence to 1 ohm and almost double the amp output (~1400W). Then you'll hear what the amp is capable of, if it can handle a 1 ohm impedence. Not all amps are design for such a beating. I know my Orion HCCAs can.
Good luck with the sale.
Jeez... I wrote "almost double" and "if it can handle". As for the impedence, sorry for the confusion. I forgot they were DVCs (Dual Voice Coils). Your explanation is correct.
Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182
HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B
Old March 19, 2008, 04:00 PM
CMetaphor's Avatar
So much arguing... so little buying... Make Offers Please!!
Old March 20, 2008, 02:09 PM
CMetaphor's Avatar
Price lowered, Bump
Old March 27, 2008, 02:18 PM
CMetaphor's Avatar
Last Bump. More Sigh.
Old July 18, 2008, 06:32 AM
CMetaphor's Avatar
Attempting to sell this stuff again, help out a guy in need! *Bump*
Old July 19, 2008, 06:26 AM
CMetaphor's Avatar
El bumpo. Take a look and ask your friends if they want some *Thump* in their trunks. Im selling the parts individually too of course so dont be shy about just asking for one thing!. At this point I need the money to start anew with my car.... so any help would be greatly appreciated!
Old July 21, 2008, 08:03 AM
CMetaphor's Avatar
Gotta sell the amp at least guys and gals, must fund me car re-build. ask your friends for me! hehe.
  #19 (permalink)
Old July 21, 2008, 09:25 AM
Chos3n's Avatar
Level up: 2% Level up: 2% Level up: 2%
Level: 8 - 177 points to level up
Positive Positive 0 0 0
Really good stuff you got there! Good luck with that
System | Fenrir
Case Antec 900
CPU Intel Core2Duo E8500 3.16GHZ 1333FSB
*NEW*
Motherboard EVGA 680i SLi P32 BIOS
Memory 4 x 1 GB OCZ 800MHZ 4-4-4-15
Video Card EVGA 8800GTX 768MB
  #20 (permalink)
Old July 22, 2008, 10:08 AM
CMetaphor's Avatar
Bump. Must sell.
Gauging Interest.. FS Striker Extreme / Intel C2D e6600 3Ghz r0k0 Buy/Sell & Trade 0 February 14, 2008 09:11 PM
audio on the cheap zaqu Audio 6 June 28, 2007 06:29 PM
no audio mo' power Audio 8 February 9, 2007 09:07 PM
