Old January 4, 2012, 04:21 PM
AmuseMe's Avatar
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default Leaking or old PC Radiators - Double Thick
Like the title states, I'm looking for old, double thick or larger PC radiators so I can recore them. As long as the tanks and side brackets are good, send me a PM.
Old January 4, 2012, 04:41 PM
Old January 9, 2012, 07:22 AM
AmuseMe's Avatar
Found the ThermoChill radiators. Now looking for RAM.
Old January 9, 2012, 07:34 AM
your board wont like hypers too much unless they 2000mhz cas7
if you find the 2000mhz 8-9-8 stuff with psc you can run 4x2gb @ 2133+
i bought a set of gskills 2x4gb 2133 cas9 runnin 2250 cas9 on the mive
only bad thing is its blue
i just switched out the gene-z for the mive
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old January 22, 2012, 03:45 PM
AmuseMe's Avatar
I need a stupid mouse pad to cut up.
Old January 22, 2012, 04:18 PM
sswilson's Avatar
Dollar store or A Buck or Two?
Old January 22, 2012, 04:22 PM
Supergrover's Avatar
I found a 1/8 cork worked wonders for pump dampening.
Sadly i dont have any pads like that around but if you do want cork I have a few rolls here. PM is key.
R.I.P.
Old January 22, 2012, 05:30 PM
jtf2's Avatar
michaels craft store
9x12 black foam sheet 1\4 inch thick 1.49
Old February 3, 2012, 10:38 PM
AmuseMe's Avatar
I need rads!
[WTB] 25mm megahalems fan clips krajee Buy/Sell & Trade 3 June 22, 2011 03:17 AM
Borrow/Rent Colorimeter acameron56 Display Units 1 September 23, 2010 10:25 PM
Looking to borrow an FX-70, FX-72 or FX-74 Dead Things Troubleshooting 23 February 2, 2010 11:07 AM
[FS] FS: Feser X-360, 17mm spacing bernZ Buy/Sell & Trade 4 November 6, 2009 09:08 PM
[WTB] Thermochill PA.120.2/3 Or Feser 240 radiator... Apollo4g Buy/Sell & Trade 0 February 18, 2009 11:06 PM
