Old January 2, 2012, 11:34 AM
Soullessone21's Avatar
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default Good Low Cost Pump 1/4 to 3/8 Barb
I need a new pump my thermaltake 760i is so loud I want to throw it out the door but I have a complete water cooling system other then another pump.
If you have a low cost pump send me a PM.
thanks so much:)
Old January 2, 2012, 11:40 AM
http://www.hardwarecanucks.com/forum...ice-drops.html
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old January 2, 2012, 12:07 PM
KaptCrunch's Avatar
DC pump or
120v cheap pump home depot 17 watts of heat dump
Old January 2, 2012, 07:45 PM
Don't cheap out on you pump, its essentially the heart of your computer. I would recommend the swiftech MCP655 for you, I believe you can get one with a speed control so if you are really concerned about noise you can run it at a lower setting
Barb and Tubing Question! Razgrtz Water Cooling 17 December 9, 2011 01:11 PM
G1/4" tap - making hole for barb NI3 Water Cooling 7 August 15, 2011 03:40 PM
barb on radiator leak CTA Water Cooling 23 February 28, 2011 12:19 PM
Swiftech MCR220 with integrated pump any good? chrisk Water Cooling 11 February 12, 2010 06:57 AM
Barb Question Supergrover Water Cooling 4 October 21, 2008 05:37 AM
