Old March 6, 2008, 08:57 PM
saihossoku's Avatar
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default WTB: Decent Water Cooling System For My Q6600
As the title states. :D I've only water cooled once and it was a crappy Thermaltake Big Water System and the damn pump died in 2 months! So only "decently" better please. :) Thanks.
Intel Core 2 Quad Q6600 "G0" 2.4GHz Overclocked @ 3.61GHz
Zalman CNPS9700 LED
Cooler Master Real Power Pro 750watt PSU
Asus Maximus Formula BIOS v1004
8GB OCZ PC2-6400 800MHz Vista Performance Platinum Edition @ 5-5-5-15 2T
Dual Radeon 3870x2's (Stock for now)
WD Raptor 74GB 10,000rpm SATA | WD 500GB 7200rpm SATA | WD 500GB 7200rpm SATA
LG DVD-RW Dual Layer SATA
Antech 900 Advance Gaming Case
42" LG LCD 1920x1080p | BenQ W5000 1080p LCD Projector 155"
Windows Vista Ultimate x64
Old March 6, 2008, 09:47 PM
Cptn Vortex's Avatar
What components are you looking to cool?
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old March 6, 2008, 10:43 PM
saihossoku's Avatar
Shoot sorry dude should have mentioned that! lol The CPU.
Zalman CNPS9700 LED
Old March 6, 2008, 11:00 PM
You will get very good results with a simple set up:
Get a Swiftech 220 RAD, the one with the built in res. It is about $50
10ft of tubing, about $10
A MCP655 pump, close to $70
An Apogee GT, then bow it with the included oring. it is very easy, and effective ($50)
Get a RadBox to mount the Rad. $15
1 set of 1/2 barbs for the RAD. The ones on the pump are built in, and the cpu block comes with its own - $2
You will need:
Various 120mm fans of your choosing
Lots of Zipties
Some Distilled water -2 litres should be more than enough.
Then you can create a simple loop like this!
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old March 6, 2008, 11:10 PM
saihossoku's Avatar
You will need:
Lots of Zipties
Wow lol, I would have zero idea how to build that! Where would I get the parts in the first place? I live in Toronto. Thanks by the way. :)
P.S. WTF is that lightning like light coming from!? Very kewl man, very kewl. :D
Zalman CNPS9700 LED
Old March 6, 2008, 11:15 PM
It is Very easy to build! Here, buy these from NCIX.com.
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old March 6, 2008, 11:27 PM
saihossoku's Avatar
That's too bad, I don't have a credit card anyway, but also that's a little over my limit of $180, any other suggestions?
Zalman CNPS9700 LED
Old March 6, 2008, 11:44 PM
Hmm well I don;t know where you can get good stuff in Toronto.
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old March 7, 2008, 12:35 AM
1Tanker's Avatar
Yes... next time mention your budget from the start.
Old March 7, 2008, 06:00 AM
low351's Avatar
Cptn Vortex I've been following WC stuff for a bit, saihossoku may not realize it but you've put it in a damn concise and no nonsense how-to IMHO. Great stuff! I would chop off your bit and make this a sticky in the Watercooling section if I were an admin here.
Saihossoku From what I've been following over the past month or so Vortex's suggestion is nearly foolproof. Wait a few weeks and save up the extra $40-60. There's nothing worse than spending $180 to get a failed solution, then losing money on the resale of the parts to eventually spend the $240 on a good solution. Trust me, my own frugalness and impatience have cost me more money than I've saved. A half decent WC solution appears to be in the $200 range no matter what you choose. You could always try one of the all in one CPU cooling solutions again but you may get the same results. Your System specs don't read like a person who's hesitant to spend...
If you want to see how it's all done then you could get a youtube video or use the NCIX basics kit videos as a starting point. Btw, the basics kit is in your price range but I couldn't vouch for the single radiator and I've heard the pump is noisy contrary to the description.
NCIX WATERCOOLING KIT
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 01:00 PM
Water cooling kit Vinnie Water Cooling 5 November 12, 2007 09:22 PM
does an arctic cooling freezer 7 pro is enought for a Q6600 ebdoradz Water Cooling 2 September 26, 2007 09:09 AM
Water cooling build SHaCK Water Cooling 34 April 24, 2007 07:45 AM
Another DIY Water Cooling Rig Magnesious Water Cooling 5 April 14, 2007 11:51 AM
