-   Buy/Sell & Trade (http://www.hardwarecanucks.com/forum/buy-sell-trade/)
-   -   WTS: OCZ ProXStream 1Kw (http://www.hardwarecanucks.com/forum/buy-sell-trade/4907-wts-ocz-proxstream-1kw.html)
cegras March 5, 2008 02:35 PM
WTS: OCZ ProXStream 1Kw - 150
Taken to RMA : )
Wankerfx March 5, 2008 03:41 PM
You should try and retake the shot so your name is visible, otherwise, it's a good sale!
Eldonko March 5, 2008 03:47 PM
Yeah other than the fact it doesnt boot your MB. How do you know it is not defective?
Wankerfx March 5, 2008 03:54 PM
He might be selling it for the discounted price because you have to RMA it or something.
cegras March 5, 2008 04:01 PM
No no, it's DEFINITELY not defective.
I've jumpered it with HDD's as load - works.
There are three documented examples of PxS not working with DFI NF4 chipset mobos. Your guess is as good as mine, really.
Do I have to? Camera phones are so picky about light ;_;
sswilson March 5, 2008 05:07 PM
Just a quick check you can do before you give up on this PSU......
I had the same issue with my OCZ 600W GameXstream paired with an Ultra-D.
Thought the PSU was toast, but for some strange reason it took a c-mos reset to get it working with the mobo.
First and only time I've ever heard of a c-mos reset for a new PSU install, but it worked, and I never had a problem with that combination again......
cegras March 5, 2008 05:42 PM
Hm. I tried doing a CMOS reset but it wouldn't power up, but that might be because it didn't like it from the start.
I had to use a surrogate PSU to get it to work, and in the process did the full CMOS clear - now running optimized defaults.
I might give it a shot, plug it in and see how it works out.
It was working fine with a GameXStream 700W, but that thing had a broken fan so I got this from the RMA.
In any case, thanks for your help - still looking to sell,though.
EDIT: Nope, no dice. I need to sell this to actually get a power supply - I'll drop the price to 190 if someone can meet me this week, or next week. GTA, UT St.George campus.
sswilson March 5, 2008 07:07 PM
Well at least you tried.... Mine was working fine with a ModStream 520W, and when the GameXstream didn't work... a 480W push-pull PSU out of a cheap case did the trick so I was sure it was the PSU.
Good luck with the sale.
Cheator March 5, 2008 07:13 PM
I can confirm the DFI NF4 is picky with PSUs. IT didn't like my Enermax 600w... i loved that thing but it wouldn't work.
cegras March 5, 2008 07:33 PM
Yep. DFI's are very picky about PSU's, apparently. I think it has something to do with the floppy and molex connector, and the extended voltage options for the memory.
