Originally Posted by 3.0charlie I'm still around, with some coffee at this time of the morning... ;-)
Which HSFs were you using with the board - 2112s?
edit: 2112, that's Rush. HSFs would be 212+s...
edit2: your avatar is killing me... what the H... is it? |
I used H212's and they were alright, but you have to mod the mounting to fit G34 and it was awkward. On the board, 2 of the cpu's are a bit closer to the ram dimms than the others, so those HSF's had to be mounted parallel to the RAM exhausting air upwards. If I had to choose, I would probably get my hands on the noctua g34 hsf's. no modding and a lot quieter than the CM h212 fans.
hehe, I found this gif at funnyjunk.com, not sure what it is from, but I found it strangely comical as well
I am going to PM you my email for emt, no response from other guy, so you gave an opportunity to buy.
