Old August 11, 2011, 12:35 PM
howpet's Avatar
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default 140 watt compatible mobo
Just throwing this in to see if anythings available and a price. Cpu is a Phenom 9950BE 140w AM2+ Bought this not even thinking it was this hot.
M-ATX preferred but this beast probably doesn"t exist
Would a 125w mobo work with this fireball with no O/C ?
Thxs
Old August 11, 2011, 02:25 PM
MARSTG's Avatar
Asus M3A78 EM is supporting your cpu and is m atx. you might want to try ebay, there are some refurbs in canada. m3n78VM also the same thing, but nvidia chipset.
Old August 11, 2011, 06:46 PM
howpet's Avatar
I knew soon as I looked up the specs being as this is an older chip there was going problems getting a resonably priced board.
Thxs MARSTG, I'm making a paper list on what to look for...anyone else got suggestions?
Old August 11, 2011, 07:07 PM
NI3 NI3 is offline
The GIGABYTE MA78GM-S2H Rev1.1 supports the PhII X4 965 140 watt officially, but for PhI chips the most officially is 125. It might be worth the try.
Gav is selling a combo that has it. If you take this combo, add in a copy of windows, and a new motherboard, you might end up gaining money if you sell it on kijiji.
http://www.hardwarecanucks.com/forum...-shipping.html
Old August 11, 2011, 07:48 PM
howpet's Avatar
Taaa (Scottish Thxs) NI3
Old August 11, 2011, 07:58 PM
NI3 NI3 is offline
I am not 100 percent sure that it would work though, google around first, just to be safe.
Old August 12, 2011, 03:29 PM
Trial Member
Undervolting to lower your TDP is your best bet. Underclocking is a good option too.
Old August 12, 2011, 04:58 PM
howpet's Avatar
Yea i've read some boards will simply not post and others will underclock it down to 1300 mhz. What a shame.
Old August 13, 2011, 04:35 AM
MARSTG's Avatar
i have the gigabyte ga ma785gm-us2h with the Phenom II X4 940@3 GHz, and it works fine, no need to underclock. will even ovc gently , never tried higher than 3.3GHz however. has 8pin power connector, works fine with my Antec Earth Watts 380. uATX
Old August 14, 2011, 06:30 PM
howpet's Avatar
Found a....GIGABYTE - Motherboard - Socket AM2+ - GA-MA790FX-UD5P (rev. 1.0)
on a free for sale site.
Waiting for reply on resonable price.
Thxs Everyone
Enough Watt? BFighter New Builds 5 April 21, 2011 03:49 PM
watt for two GTX 295 hohohee Video Cards 24 September 24, 2009 08:49 PM
Is a 750 watt PSU Enough? Rocco_360 New Builds 17 March 20, 2009 01:48 PM
FS-s939 X2-3800, OCZ ram, Ac Freezer 64 Pro, ASRock mobo, DFI mobo, Asus mobo..more stoanee Buy/Sell & Trade 14 June 7, 2008 06:24 PM
Will my mobo be compatible? Shiverwarp RAM 1 July 19, 2007 04:14 AM
