Old November 19, 2010, 01:18 PM
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default Motherboard Stand-offs
So i bought a new case a while ago and i was too lazy to transfer everything over till like 2 months after i bought the case and Thermaltake kindly forgot to put in a package of stand-offs. I called them and there is nothing they can do since its not within 10 days of purchase and Canada Computers said they can do nothing for me. Last time i will be purchasing from them (thermaltake).
So i need 9 standoffs of this size (thanks thermaltake rep)
i7 920 D0 @ 4ghz
Custum WC Loop
Asus P6X58D-E
6 Gb Corsair 1333
EVGA 760 GTX
NZXT Phantom
Old November 19, 2010, 01:20 PM
sure theyre not already screwed in the case? haha
i've thought i didn't get but was in case already few times
Old November 19, 2010, 01:26 PM
no they arnt in the manual is shows a picture of the package but mine was lacking
i7 920 D0 @ 4ghz
Custum WC Loop
Asus P6X58D-E
6 Gb Corsair 1333
EVGA 760 GTX
NZXT Phantom
Old November 19, 2010, 01:28 PM
I think I have some, let me find them out.
Your picture isnt showing though
Edit: I dont have them
Old November 19, 2010, 01:39 PM
Picture attached to forum
i7 920 D0 @ 4ghz
Custum WC Loop
Asus P6X58D-E
6 Gb Corsair 1333
EVGA 760 GTX
NZXT Phantom
Old November 19, 2010, 01:49 PM
CTA's Avatar
CTA CTA is offline
try ackland but you might have to buy 100 stands off..
or try Buy the Ultra Computer Screws at TigerDirect.ca
i also am looking for two stand off tho... i will need to buy the new case (for my brother) and take one or two extra from them... >_>;
edit: i found a couple item that sells... just search it...
this is cheapest one i found.. 15-pk 6-32 Standoffs - Brass STANDOFF632
Old November 19, 2010, 01:55 PM
FiXT's Avatar
Hall of Fame
I know this is off topic, but holy crap that is pathetic of TT and CC.
Honestly, you'd think a company would better support the end user. I'd had no trouble with Silverstone or Coolermaster sending me spare parts, like drive bay caddies at absolutely no cost, sometimes Antec as well depending on the product.
And for CC to not be able to help you out. Computer shops have handfuls of screws and mounts and such just laying around... is it seriously to hard for them to take a couple minutes and pick out 9 standoffs o.O
If you don't find anything local, I am sure I can dig up some 1cm ones and postage them out to you - let me know
Old November 19, 2010, 02:18 PM
Like i said this will be the last time i purchase a thermaltake product.... it is ridiculous to pay 120 for a case and they wont send you stuff that costs under 3$ with shipping
i7 920 D0 @ 4ghz
Custum WC Loop
Asus P6X58D-E
6 Gb Corsair 1333
EVGA 760 GTX
NZXT Phantom
Old November 19, 2010, 02:19 PM
rjbarker's Avatar
^^^ I think I may have a bunch kicking around as well.....
Firestrike Extreme: 23.772K
https://www.3dmark.com/fs/17562471
Timespy: 18.613K
MARK 11: 40.185K
https://www.3dmark.com/3dm11/13079691
Old November 19, 2010, 02:23 PM
Soultribunal's Avatar
Its funny really. I had great CS from TT over the years on various things. Its like night and day on who you get and how idiotic they want to be.
I got burned by Antec on something similar and since then have never purchased another case from them.
That being said, I have probably 1000 at my house (I bought one of those really neat Tech Kits back in the day) and it has everything you could want and more for computer hardware fastening.
ST
www.realhardwarereviews.com
3-Monitor Arm / desk stand BobbyLou Peripherals 7 August 17, 2010 10:44 AM
Quick Disconnects/Shut offs JD Water Cooling 3 December 27, 2008 01:21 AM
looking for some motherboard stand offs klaiboi Buy/Sell & Trade 5 November 18, 2008 11:17 PM
ESA Bullying, Where do I stand(legally)? ChuckleBrother O/S's, Drivers & General Software 53 October 17, 2008 09:26 PM
Future Shop Boxing Day Rip Offs. Scotch Tape Off Topic 12 January 6, 2008 09:30 AM
