Old September 19, 2010, 11:33 AM
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default 3-pin Fan Splitter (3-way)
Hello, I'm looking buy a 3-way 3-pin fan splitter.
Everything I find in Canadian retailers (well, just NCIX and Daz so far) are only Y splitters (only 2 fans!)
I'm hoping someone has a spare 3way splitter for sale or could possibly point me in the right direction to find a retail.
Thanks!
One other question is..
If my 3 fans are all same and rated at 0.25amps, would my kaze master ace (which is 1amp per port max) be sufficient to run all 3? I would assume yes, based on the numbers, but just want to make sure.
Thanks again!
Edit: Can I use 2 Y-splitters and link them to make 3 fans connect? Would changing fan speed on the fan controller affect speed the same way on all 3 fans?
Old September 19, 2010, 11:43 AM
stoanee's Avatar
Newegg.ca - Rosewill 12" PWM Splitter Model RCW-FPS-401
Maybe this?
heatware
Old September 19, 2010, 12:00 PM
Hey thanks, that might work!
I am wondering though, it seems only the blue wire from each 3pin fan header will actually go to my fan controller.
Will that provide the power to the fans - also fan speed control? (As I don't intend on using the 4 pin PSU connector)
The one green wire from one of the fan headers = RPM monitoring?
If that's so that's what I want!
Edit: Also $7 shipping Too bad NCIX does not carry Rosewill stuff to PM heh
Old September 19, 2010, 12:05 PM
Astaroth's Avatar
I think you'd be better off if you PM two of these: http://www.ncix.com/products/?sku=31...ufacture=Works
I've used one of them with a fan controller with great success. So I don't see why linking a second one together to make a 3rd port wouldn't work just as well. As long as the controller can handle 36v you're fine. You will also like the pm.
Old September 19, 2010, 12:09 PM
Astaroth's Avatar
As long you plug the second one into the Black, yellow, red, plug it should work fine.
Fractal designe Fan splitter one 4 PIN to 16 Conectors ZZLEE Air Cooling 4 April 21, 2010 10:37 PM
[WTB] (GVR) 3 pin Y Fan Splitter & RAM Sinks jcmaz Buy/Sell & Trade 3 April 21, 2010 04:17 PM
CPU Fan Splitter Plug FreeKnight Air Cooling 5 February 8, 2010 09:53 AM
Fan Controller : Can you use a Splitter? BobbyLou Air Cooling 5 December 8, 2009 11:57 AM
3 Pin to 4 Pin Fan Plug Adaptor? Thund3rball Video Cards 6 March 25, 2008 01:46 PM
