Old June 2, 2010, 06:52 PM
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default Swiftech hose clamps...
I'm currently looking for some Swiftech plastic hose clamps for 1/2" i.d. tubing (3/4" o.d.). If you have any you can spare, LMK and I'll purchase them. Thanks. I need 10 of them.
Old June 3, 2010, 07:01 AM
AmuseMe's Avatar
You mean the herbie clamps/ crocodile ones? I am pretty sure that I have a bunch, I'll take a look. You could always use zip-ties. I personally think that they look cleaner.
Old June 3, 2010, 07:45 AM
gingerbee's Avatar
they sell them at hardware stores.
Old June 3, 2010, 05:11 PM
Where? So far I've checked Canadian Tire, Lowes and Home Depot with no luck! :(
Old June 3, 2010, 07:53 PM
gingerbee's Avatar
home hardware plumbing section make sure you go to one that has all the gas fitting and stuff they have great for water cooling it.
this is another place online but they do sell them lots of other places Plastic Hose Clamp
you can use zip tie's too
Old June 4, 2010, 05:30 AM
I'll check out a Home Hardware then. :) Thanks for the tips....
Hose staining? frosty Water Cooling 14 January 25, 2010 10:54 PM
How do you guys cut your hose? rai_polo Water Cooling 30 November 2, 2009 12:51 AM
Do hose lengths matter ? Shadowmeph Water Cooling 4 July 17, 2009 05:08 PM
Swiftech radbox Dr_BenD_over Water Cooling 5 October 28, 2008 06:16 AM
wormdrive hose clamps nikitos Water Cooling 6 June 19, 2008 11:16 PM
