Old May 10, 2010, 11:49 PM
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default 775 cpu, ddr2 ram/bare basics multi-GPU system/ 6pin and 8pin PCIe cables (modular)
UPDATE: Need a cheap 775 cpu for under $40, ddr2 ram 2 gigs 2x1gb is fine any speed. Need these ASAP.
Also in dire need of some modular 6pin and 8pin PCIe cables, any manufacturer is fine. If anyone has an old modular Ultra PSU that will work just fine as well as I'll take any unused cables you may have :D
Thanks!!!
OLDER post below:
Hey guys, I'm in need of a cheapy SLi capable system that I can test hardware on and Fold in spare time when I'm not doing testing.
Needs to have: case (any, but full tower would be preferred for easy access), motherboard that uses 24pin power, ram (2gigs is sufficient), video card (any PCie card is fine), PSU (around the 600w+ range would be nice).
I will be straight up and honest here and say I'm not looking to spend more than a couple hundred bucks on this ($200 :P)
PM me if you have anything like this kicking around, Intel or AMD, doesn't matter.
Thanks!
Old May 11, 2010, 11:21 PM
Hey guys, if you have anything in that price range let me know, video card no longer a prereq and neither is a case (found those on the cheap)
Will consider single slot systems too if they strike my fancy!
Old May 12, 2010, 02:04 PM
Money is negotiable, if you have something within a hundred bucks ($300) like a CPU, mobo, ram combo I may be interested too
Old May 12, 2010, 11:43 PM
HaDeS
Guest
Posts: n/a
200 bux? Better sharpen your pencil mate and dig a little deeper.
Old May 13, 2010, 01:31 AM
Nah, can get some decent older tech for that price, as I said, this will just be used for testing so I don't care what cpu/ram I get, as long as the mobo is decent-ish.
Also, if you look at my post above, I'm willing to go $300 on cpu/mobo/ram depending on what it is.
Don't expect people to give things away, but for $300 I can slap together a semi-decent i3 combo that will be more than sufficient and it will be BNIB.
Old May 17, 2010, 08:38 AM
Buuump :)
Old May 18, 2010, 09:47 AM
Ram is pending, NEED A CPU STILL!
Would love to throw a cheapie C2D in there :D
Old May 18, 2010, 11:09 AM
I have a 3.2/800 single core 775 if you're interested.
Old May 18, 2010, 12:15 PM
i have e6600 2.66ghz for $80, or e6850 3ghz for $95, if you are interested.
Old May 19, 2010, 06:10 AM
Bumpppsss
Need cheapie CPU's guys, this will be used for the test-rig since I can't seem to find one that will fit the specs of 'cheap'.
[FS] AMD 6400+ System, Socket A Bare, LG-Blu-ray, ATI X1800XT... The Destroyer Buy/Sell & Trade 0 February 3, 2010 09:32 PM
On a three way SLI capable board.... orcrowing Video Cards 3 February 26, 2009 06:54 PM
New Nvidia Drivers / SLI Multi Monitor + SLI on X58 - 180.48 probationer O/S's, Drivers & General Software 14 November 26, 2008 08:40 AM
Tri SLI, Quad SLI, SLI comparisons with 9800GTS, GX2 Babrbarossa Reviews & Articles from the Web 3 March 31, 2008 02:32 PM
