Old February 3, 2010, 01:24 AM
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default Mini-ITX mobo
I'm looking for a mini-itx motherboard, new, used, it doesn't matter. Only requirements I have are that it has a PCI-E16 slot on it and it be either AM2/AM3 or LGA775. Trying to make a low powered rig for LANing and downloading. Not sure if PCI-E1 would be able to run a gpu, but if you've got something that you think might work, send me a PM. I live in B.C. and will pay however you would like me to.
Thanks everyone
Old February 3, 2010, 03:45 AM
MarkOne's Avatar
Look at new egg Zotac have a lot of good board with pcie... even one with a P55. ( not available for now at new egg )
Old February 3, 2010, 05:06 AM
3.0charlie's Avatar
I have a brand new Intel mini-Itx board, but my memory is failing. Back Home, I'll reply with the exact number.
Hydro-Quebec is salivating...
Old February 3, 2010, 04:23 PM
3.0charlie's Avatar
Back Home. Forget about it, no PCI-e x16 on that one...
Old February 3, 2010, 06:09 PM
yamawho's Avatar
I have this but no pci16 ...
Mini-ITX LAN/download box Kovok New Builds 32 February 5, 2010 09:03 AM
Zotac Releases New ION ITX-F Mini ITX Solution FiXT Press Releases & Tech News 6 October 1, 2009 05:47 AM
Mini-ITX NAS within a PC (TJ-07) Caznoob New Builds 10 June 25, 2009 05:23 PM
Mini-ITX MB? dcproulx HTPC Systems & Software 8 May 10, 2009 03:24 PM
A Quicky Mini ITX setup. Dr_BenD_over New Builds 15 October 29, 2008 01:30 PM
