Old August 10, 2009, 12:02 AM
chouchou's Avatar
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
PM'd
and to answer your question MPG, yes i have checked out the specs on his comp, and have confirmed that he has PCI-E.
What do you mean by proprietary PSU wiring? can u elaborate.
Cheers
HAF932
Q6700stock || SLI GTX 260 c216 =) || 2x2gbMushkinRedline PC2-8000
750i FTW || WD 36GB Raptor || WD 640GB Caviar Black || HX620W
Old August 10, 2009, 01:49 AM
MpG's Avatar
MpG MpG is offline
If the computer is an OEM (not home-built), some of them use unique wiring patterns that don't follow ATX specifications. The plug holes may look the same, but plugging in a regular PSU will fry the system. It's basically a scam to make sure you have to get replacement parts from them. For example, Dell is/was notorious for this, which is why some companies sell specific replacement units for them. You didn't mention any details about your friend's computer, so I figured it couldn't hurt to double-check.
Old August 10, 2009, 01:54 AM
chouchou's Avatar
Ah. his is a HP Media Centre PC with ATX specifications... Shoot... I hope this isn't the case :S
HAF932
Old August 10, 2009, 07:50 PM
chouchou's Avatar
uuuup
HAF932
Old August 11, 2009, 11:14 PM
chouchou's Avatar
bumpzors
4 days!
HAF932
Old August 12, 2009, 03:21 AM
I offered you psu, did you want it? bnib antec earthwatts 500w
Old August 12, 2009, 04:50 PM
chouchou's Avatar
sorry for the late replies, was in a rush and forgot about the pm's i had already clicked.
bump for the day and off to work!
HAF932
Old August 13, 2009, 07:55 AM
chouchou's Avatar
up for school. looking for a couple more days.
i was thinking if i can't get from HWC, i'll grab an antec basic 500w or coolermaster 500w and a 9500gt that'll cost me just under 150.
NCIX.com - Buy Antec Basiq BP500U 500W 24PIN ATX 12V Power Supply Active PFC - BP500U In Canada.
NCIX.com - Buy Coolermaster Extreme Power Plus 500W ATX 12V V2.3 Silent Power Supply 20/24PIN 120MM Fan - RS-500PCAR-A3 In Canada.
NCIX.com - Buy XFX GeForce 9500GT 550MHZ 1GB 800MHZ DDR2 PCI-E DVI-I HDCP HDTV Out Video Card - PVT95GZAFG In Canada.
HAF932
500w psu enough? donkon Power Supplies 3 June 20, 2009 06:40 PM
PSU Vid Card Compatibility Kliment Video Cards 7 June 16, 2009 05:55 AM
Wtb: Psu ~500w chouchou Buy/Sell & Trade 2 November 3, 2008 05:37 PM
A teaser of the 500W PSU Roundup!! SKYMTL Reviews & Articles from the Web 9 March 14, 2007 05:37 AM
