Closed Thread
Old August 2, 2009, 05:43 PM
SugarJ's Avatar
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default Bitspower 45 Deg Rotary Fittings
I'm in need of 2 each of the 45 degree fittings seen here:
NCIX.com - Buy Bitspower Single G1/4 Rotary 45 Degree Angled Fitting Adapter G1/4 Threaded - BP-45R In Canada.
NCIX has 1 only in stock. Anyone got any spares? The finish doesn't matter as they will be hidden.
Thanks,
Gord
Old August 3, 2009, 08:52 AM
SugarJ's Avatar
NVM. I had an epiphany last night. I can just spin the rad end for end. Makes one tubing run a little longer, but fixes my issue. It's funny how things get locked in your head and you don't see the options.
Thread can be closed / deleted.
Closed Thread
[FS] Bitspower Compression and other fittings mhw100 Buy/Sell & Trade 1 July 15, 2009 02:16 PM
[FS] Bitspower compression and other fitting mhw100 Buy/Sell & Trade 12 June 22, 2009 07:41 AM
Bitspower G1/4 Straight Compression Fittings BALISTX Water Cooling 8 October 12, 2008 10:19 AM
Bitspower Fittings JD Water Cooling 10 August 14, 2008 10:29 PM
flow restriction on 90 deg fitting? sswilson Water Cooling 8 September 26, 2007 02:41 PM
