Old June 14, 2009, 08:51 AM
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default Highquality CRT monitor
Im looking to buy a high quality crt monitor, these would include the:
SGI G520k
Sony GDM 5411
Sony GDM FW900
Samsung 997mb
NEC Multisync FP1375X
PM me if you have any of these monitors with a resonable price.
Also looking for local delivery, as shipping would be fairly expensive, weight and all.
Im located in toronto ontario,
Exact address is 34 st dennis drive, area code is m3c1g6 for mapquest purposes.
Old June 14, 2009, 10:00 AM
Amon's Avatar
Where are you located?
Old June 14, 2009, 11:33 AM
Amon's Avatar
Although not on your list, I have an NEC 6FGp.
The specs that I know are:
21 inches commercially documented (20" viewable, physically), not flat-screen
BNC and D-sub (9- and 15-pin) inputs simultaneously, with a toggle switch on front
Up to 1600x1200 @ 60Hz
Dot pitch unknown (.27 ?)
Colour vibrancy looks good
Very faint colour fringing in far corners (not calibrated; might want to use legacy Macintosh 1.8 gamma instead of 2.2)
Sharpness not as good as modern LCD technology; naturally antialiases hard lines
Additional info:
Circa 1996
~35kg weight
Minor scuffing on plastic chassis over the years, screen untouched
Permanent Velcro pad on the left side of body for when I used to mount my old-school Mini-disc player during a long session; you might find an alternative use.
90-degree swivel base in perfect condition; tilts 5 degrees down or 10 degrees up
will heat up your room in an hour
Are you interested? PM an offer if you are. Located in Brampton, ON, I'll deliver.
[WTB] Looking to buy CRT Monitor. MrFoxx Buy/Sell & Trade 8 June 9, 2009 11:50 PM
new monitor djnocide Display Units 3 November 30, 2008 10:38 PM
Could i dual screen with a moniter & a CRT TV? Kayen Display Units 5 July 28, 2008 12:43 AM
What should I ask for this monitor mailaw Display Units 4 May 1, 2008 11:43 AM
New Monitor? s_8ball Display Units 3 April 19, 2008 06:50 AM
