Old May 29, 2009, 03:24 PM
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default Bitspower compression and other fitting
Bitspower 45 degree angled - $8/each. SOLD
Bitspower direct connect (C-38) D-plug - $8.
Bitspower Crystal T block - $3. SOLD
Bitspower transfer case - $3/each.
Swiftech fill port 1/2" - $8.
Primochill black tee 1/2" - $2.
Rubber grommets 5/8" OD - $2/pair. SOLD
Bitspower temp sensor stop fitting - $6. SOLD
Primochill worm clamps 5/8" OD - $1.50/pair.
Bitspower stop fitting - $3/each. SOLD
Bitspower compression 1/2"ID-3/4"OD - $7/each. SOLD
The above are all G1/4. They are all new within the last 2 months and mounted only once to ensure they were not leaking.
Above prices are exclusive of shipping which in a small package shouldn't be too high depending on where you live in Canada.
Payment by EMT.
Thank you.
Old May 29, 2009, 03:30 PM
SugarJ's Avatar
Are the compression fittings for 3/4 or 5/8" OD tubing?
Old May 29, 2009, 03:52 PM
3/4" - bought from NCIX. Edited ad above.
Old May 29, 2009, 04:21 PM
S_G's Avatar
S_G S_G is offline
Yhpm.
HTPC: MSI Z77A-G43 + i5-3570k@4.6 + 16GB DDR3-1600 + GTX 580 + X-Fi Platinum on water
Work: 13" MacBook Pro Retina 512GB
Old Workstation: X7DWA-N : 2x Xeon E5330 Quads @ 3GHz + 24GB FB-DIMM DDR2-800 on water
1x 8800 Ultra --> Sony GDM-FW900 + LVM-37w3se // HT Omega Striker ~ (optical) Pioneer SE-DIR800C ~+ SE-DHP800 / HD 280 Pro
Old May 31, 2009, 11:04 AM
bump..
Old May 31, 2009, 11:09 AM
Phobia's Avatar
YGPM..
(whitty saying to be plagiarized at a later date)
Old May 31, 2009, 12:07 PM
Pictures arent showing up
heatware
ebay
Old May 31, 2009, 01:15 PM
showing up here.
Old June 1, 2009, 06:23 PM
bump..
Old June 2, 2009, 07:45 AM
bump..
Compression Fittings micul Water Cooling 5 April 18, 2009 03:21 AM
Bitspower G1/4 Straight Compression Fittings BALISTX Water Cooling 8 October 12, 2008 10:19 AM
New Bitspower goodness coming..... Cptn Vortex Water Cooling 2 September 26, 2008 05:16 PM
Bitspower Fittings JD Water Cooling 10 August 14, 2008 10:29 PM
compression fittings in Canada? lowfat Water Cooling 2 April 30, 2008 12:37 PM
