Old May 12, 2009, 09:41 AM
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default Thermalright 120 Extreme, Ultra Kaze 3000, Blue LED
1. Lapped Thermalright Ultra 120 Extreme...includes extra set of fan clips for push/pull. Bad pic of lap job but it is smooth/levle although if you like a polished look you will want to apply a fine grit to it. $45 SOLD
2. Blue cold cathode LED...used for about 4 months. $3 each or $6 for the new box. 4 SOLD
3. Ultra Kaze 3000 rpm fans...used for about 4 months. $5 each. ALL SOLD
I don't know what the shipping will cost but it always seems to be somewhere between $8-$12 with Canada Post.
Payment by EMT is preferred as Paypal seems to be getting greedy.
Thanks.
Old May 12, 2009, 12:05 PM
Realityshift's Avatar
Do the CCFLs come with the controllers and backplate switches?
The Builders Hammer
Old May 12, 2009, 12:43 PM
No there are no controllers - the only thing they come with are those little blue boxes (covered up by my sig sheet in the pic) which is wired to a molex. You can't adjust the lighting brightness.
Old May 12, 2009, 12:52 PM
Thats what I meant by controllers =) I guess you could call them converters too but they turn the lights on and off. YGPM.
The Builders Hammer
Old May 12, 2009, 01:33 PM
No, there isn't a switch on the converter that turns them on or off. The only way to do that is to unplug the molex or unplug the LED.
Old May 12, 2009, 01:36 PM
If those are logysis lights then there should be a switch mounted on a backplate that sits in an unused PCI slot for turning them on and off? Any of the ones ive seen do anyhow.
The Builders Hammer
Old May 12, 2009, 01:43 PM
Oh I see what you mean. I thought you were asking about a switch on the converter. Yes, there is a switch but it is no longer on a PCI bracket. It's on a backplate as you say but I dumped the PCI bracket and no longer have it.
Old May 12, 2009, 01:49 PM
S_G's Avatar
S_G S_G is offline
Darn, those fans went fast! On a side note, I have no idea why they designed the CCFLs like that. I don't know of anyone who actually uses the PCI bracket.
HTPC: MSI Z77A-G43 + i5-3570k@4.6 + 16GB DDR3-1600 + GTX 580 + X-Fi Platinum on water
Work: 13" MacBook Pro Retina 512GB
Old Workstation: X7DWA-N : 2x Xeon E5330 Quads @ 3GHz + 24GB FB-DIMM DDR2-800 on water
1x 8800 Ultra --> Sony GDM-FW900 + LVM-37w3se // HT Omega Striker ~ (optical) Pioneer SE-DIR800C ~+ SE-DHP800 / HD 280 Pro
Old May 12, 2009, 01:56 PM
Yeah, I don't either given the pain it takes to wire them over to the I/O side.
Old May 14, 2009, 07:30 AM
bump...
Thermalright Ultra 120 Extreme orientation? Bones Air Cooling 23 April 25, 2009 06:56 PM
Thermalright Ultra 120 Extreme Mulder Air Cooling 5 September 30, 2008 12:37 AM
FS: Thermalright Ultra 120 Extreme JD Buy/Sell & Trade 5 July 14, 2008 03:49 PM
WTB Thermalright Ultra 120 Extreme rom0n Buy/Sell & Trade 18 June 1, 2008 01:43 PM
A second look at the Thermalright Ultra 120 eXtreme Babrbarossa Reviews & Articles from the Web 2 May 4, 2007 06:23 PM
