Old May 9, 2009, 07:27 PM
Apollo4g's Avatar
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Exclamation Mountain Mods Ascension Duality - Sky White
SOLD
Well its time to start a new project, so im planning to sell this baby.
Its a MM Ascension case, sky white and its the CYO version which means you can buy separate custom panels to your liking via MM and just replace the current ones. It has Thermochill radiator spacing in the front.
Its a duality and holds 2 full computers as well as it has 4 PSU mounts.
Its in excellent condition besides the normal wear and tear on the screw holds and where the PSU mounts, but other than that nothing.
It comes with all the parts that came with it from MM, plus some custom pieces i bought like a 2x120mm fan mount to replace the other mobo tray, and extra PSU covers, 3x5.25 bay covers, blue acrylic feet, casters,
Comes WITHOUT the grills, vandal resistant switches and hardware of course, case only.
Any other question shoot me a PM, or just post here if you think they will be useful to other people.
SOLD
Link to MM, its the exact same case, mines just white.
MountainMods.com-Computer Cases-Ascension Duality-Ascension - Duality (Mirror Black Powder Coat) - Original Top
ASCEND to new heights with a Mountain Mods Ascension aluminum computer case!
The Mountain Mods Ascension adds 6 inches of height to the already massive U2-UFO platform. The behemoth stands 24 inches tall and is 18 inches deep and wide. The Duality configuration allows for two motherboard trays in a vertical position in the case. On the lower front 6 x 120mm intake fans are positioned for two world renowned Thermochill PA 120.3 radiators. On the back wall another PA 120.3 radiator can be mounted above the motherboard tray. Also on the back wall are 4 Power Supply ports - two in the lower center and two way up in the right and left corners the MB trays. Not watercooling? No problem - each of these 120mm intakes and exhaust ports can be used in conjunction with our 120mm Hard drive brackets. Each hard drive bracket is capable of holding 3 x HDD's. This would allow for the use of 27 Hard drives by using the 120mm ports alone. As if this wasn't enough - the Duality Mountain Mods Ascension can hold up to 10 x 5.25 devices. Using our triple bay 120mm fan mounts could get one up to 33 hard drives for the most massive of servers at a moderate cost. The Ascension like the U2-UFO is COMPLETELY MODULAR - or "HYPER MODULAR" as we call it. The front and back panels can rotate 180 degrees for a different configuration. Or easily change your configuration by purchasing individual panels. The Ascension is fabricated by skilled workers in the USA. It is made from thick aluminum making it lightweight, sturdy, and thermally friendly. Casters are included for easy mobility.
Discover more space - ASCEND!
Assembly INSTRUCTIONS same as the U2-UFO
Specifications:
Material - Aluminum 5052
Thickness - 1.65mm-3.25mm
Dimensions - 24x18x18 inches
Finish - Powder Coat
Power Supplies - Holds up to 4
HD Bay - 2 sets of 120mm HD brackets - Holds 6 out of box, up to 27!!
5.25 Bay - 2 x Removable
5.25 Devices - Holds 10
MB Tray - 2 x Removable
Form Factors - mATX/ATX/EATX (EATX choose the optional MB Tray)
Fan Mounts - 11-120mm, 4-80mm
Empty Weight - 18 lbs.
Here she is all disassembled.
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Old May 9, 2009, 09:04 PM
any chance you want to sell a fan controller and the 2 5.25 bay scythe fans,i have a MM opti-1203 gloss white, they would go great in .. or point me to where you purchased them.
or did you paint them? was thinking of maybe trying to paint my black ones
lmk
Thanks
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old May 9, 2009, 09:05 PM
Apollo4g's Avatar
I painted them, :)
They are sunbeams.
Old May 9, 2009, 09:16 PM
ahh ok.. looks sweet i almost purchased a scythe master ace,to replace my nzxt sentry's but im glad i seen your pic, getting me a sunbeam and a can of spray paint :)
if you decide you want to sell the bay fans i am interested
good luck with your sale
Old May 10, 2009, 12:30 PM
Apollo4g's Avatar
bumpage
Old May 10, 2009, 05:28 PM
Id be all over this, But the Price is Extrem to me...
500$ for a Case. ?
Old May 11, 2009, 04:06 AM
S_G's Avatar
S_G S_G is offline
@Chromey
That's pretty much threadcrapping, dude. The Ascension Duality
  • can hold two motherboards
  • can hold four power supplies
  • has a white powder-coated finish
  • can hold 13 fans
  • with the fan trays, can hold dozens of hard drives (I don't remember the exact number, as I'm not sure how many of the fans can be outfitted with a tray without blocking something; probably 24-38)
  • can hold 16 more drives with 2x 5-in-3 + 2x 3-in-2 5.25" adapters
  • can alternatively hold a crapload of radiators on those fans
I could go on, but these are the main features. Some of us pay well over $200 for cases. Consider buying two such cases for two motherboards, and you've reached the price of the Duality, without having many of its features.
HTPC: MSI Z77A-G43 + i5-3570k@4.6 + 16GB DDR3-1600 + GTX 580 + X-Fi Platinum on water
Work: 13" MacBook Pro Retina 512GB
Old Workstation: X7DWA-N : 2x Xeon E5330 Quads @ 3GHz + 24GB FB-DIMM DDR2-800 on water
1x 8800 Ultra --> Sony GDM-FW900 + LVM-37w3se // HT Omega Striker ~ (optical) Pioneer SE-DIR800C ~+ SE-DHP800 / HD 280 Pro
Old May 11, 2009, 05:55 AM
matsta31's Avatar
That is the case, new. The price is in us $. And you need to pay shipping+ duties over and above... some little reaserch would help...
Sold hardware again.....
Currently using WHS hardware....
Old May 11, 2009, 01:17 PM
I didnt mean to thread crap at all,
ANd to be Honest some of us pay more then 200$ for a case as well.
Id list my current cases But that would take us no where.
And Im trying to get the fund together for this as we speak.
[WTB] Mountain Mods UFO case (prefer white) Toronto122 Buy/Sell & Trade 0 February 16, 2009 07:17 AM
Mountain Mods H2go Infiniti Cases 0 October 17, 2008 10:07 PM
Apollo4g's Mountain Mods Ascension Duality Apollo4g Case Mods, Worklog & Gallery 25 October 3, 2008 07:37 PM
FS: Mountain Mods Horizon Case - Sky White Apollo4g Buy/Sell & Trade 23 May 19, 2008 05:44 PM
